Old 1st June 2003, 05:24 PM   #1
jazzy is offline jazzy  Slovenia
jazzy's Avatar
Default My baby is HOT!!
My baby is hot ,very hot too hot for me.
I can't even touch her.
Perhaps she need a bigger...... ...heatsink??
OK anyhow:
¸TEST A5 monoblocks (without exotic parts- resis., semiconduct., caps.ect) in sort-of test enclosures.
- PCB own design
- Heatsink dimensions 30 X 12 X 4 cm
PSU:
- 2 X 35A/200V Bridge
- 2 X 27 V 350W Trann. + CL 70
- 2 X 50kuF this moment without Pi filter ( 2,2mH)
- 2X 36 V Rail
Power Mosfet resistor:
- 2 X 2,2 Ohm 2W Noninduct. parallel ( 0,575 V )
Output resistors:
- 8 X 1 Ohm 1W Noninduct. parallel.
Tomorrow I will check HS. temp with termometer and find possible oscilation with scope!
J.Z.
Old 1st June 2003, 05:26 PM   #2
jazzy's Avatar
Default Hot baby pic .
More pics.!!
jazzy
J.Z.
Old 1st June 2003, 05:35 PM   #3
jazzy's Avatar
Default Hot baby pics.
jazzy
J.Z.
Old 1st June 2003, 05:37 PM   #4
jazzy's Avatar
Default Last pics!
jazzy
J.Z.
Old 1st June 2003, 08:01 PM   #5
Send a message via MSN to Tazzy
How high did you set the bias?
And, how hot does your amp run exactly?
Old 1st June 2003, 08:05 PM   #6
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
sinks do look a little small... put a fan on them or find a bigger
sink. FET spacing looks to small too. It would be nice if you had
2 more sinks just like that... split your fets between them with
more spacing...
the quality of your work is very nice though!
heat sinks... can never be too big!!
good luck,
m.
Old 2nd June 2003, 12:05 AM   #7
I would split up those devices and double your present heatsinks.....at least.....
Bacon and Eggs ala Aleph honey?
MArk
Old 2nd June 2003, 04:04 AM   #8
Circlotron's Avatar
On some tests I did last year on heatsinks I found a fan would improve the heatsink perfrmance by a factor of 6. Yep, six times as good. I have dumped as much as 350 watts onto a 100mm x 100mm sink with a 90mm fan going full blast, but that was really the outer limits.
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 2nd June 2003, 04:25 AM   #9
jwb is offline jwb  United States
jwb's Avatar
Send a message via AIM to jwb
Yeah, of course. Fans are awesome. But more importantly I see a lot of designs on this site with the transistors all in a line. This is a huge waste of the heatsink's ability. Space them evenly on the surface of the sink, and you will get much better performance.
The transistors in the picture above are WAY too close together. Most of this heatsink is wasted.
Old 2nd June 2003, 11:07 AM   #10
I did some testing with thermal calculation software and there almost no difference in placing the mosfets when you have thick enough back plate (>10mm will do) . There was only a 4 degree difference between the mosfets in placing them in line and all spread around... hardly worth the trouble in wiring, buy more heatsink to compensate this!
I did some measurements on my running Aleph 4 and there is almost no difference between the left, the top the back and bottom when all is in balance after 60 minutes of running... All is hot!
Ofcourse his mosfets are a bit too close and his heatsink look too small...
Edwin
My new baby amp suzyj Solid State 21 19th May 2009 03:11 PM
My new baby GrahamnDodder Chip Amps 42 18th October 2003 03:49 AM
A Baby Zen V2 jh6you Pass Labs 13 1st October 2002 03:44 PM
Page generated in 0.12192 seconds (77.25% PHP - 22.75% MySQL) with 11 queries
