#121 | |
Ahe is (www.specmail.nl) local electronicshop. And sells matched fets. Don't know if they deliver over the big pond .
#122 |
Edwin,
Great write up. Your ran a test for R12 and R34. What values did you choose?
Paul |
#123 | |
I used 2k potmeters to start off, I set the initialially at 1k. After applying a 1khz sinus wave of about 9V RMS into a 8 ohm load, I adjusted these potmeters to get an even gain of 50% of the active current source . After adjusting I measured the 2k potmeters and they were about 780 ohm ! So it is best to go this route as the value is very dependend of amount of mosfet's used and the value of the bias resistors. Hope this helps, Edwin |
#124 |
Edwin,
A stupid question perhaps : How exactly did you adjust R12 R34? How do you measure the gain of the active current source to know it is exactly 50%? Thanks, Patrick |
#125 |
Edwin...Please contact me off board, urgent!
Steve |
#126 |
The best way and perhap the only accurate way is to disconnect the trimer, apply 16 volts 100 hertz to an 8 ohm load at full temperature. Measure the a.c volts across the lower source resisters then measure again with the trimmer in circuit until the desired a.c voltage representing 50% current share is obtained.
imac |
#127 | |
| Smoke coming out from my Aleph.... Please HELP! | lscangus | Pass Labs | 25 | 18th July 2006 08:42 PM |
| AES coming to NYC Oct 7-10 | jackinnj | Everything Else | 0 | 14th August 2005 07:00 PM |
| Zen V7 coming up... | Fuling | Pass Labs | 6 | 21st October 2004 09:39 PM |
| New Aleph 5 coming up!! | bbakota2000 | Pass Labs | 20 | 18th April 2004 03:05 PM |
| Page generated in 0.21435 seconds (35.40% PHP - 64.60% MySQL) with 11 queries |
