I know I've seen some discussion of this before, but I cannot find it using the forum Search.
Can I drill out the hole in an IRF240 to make it big enough to accommodate an M4 screw without damaging the transistor or should I mount them with a smaller screw? I was planning on using M4 screws to hold the chassis together and didn't really want to play with tapping different sized holes... Thanks, Eric |
#2 |
I've drilled them 5/32 to clear #6 screw no problems
Cheers! |
#3 |
You can, but just be aware that if you warp the part by clamping it too tightly, you'll crack the silicon- a bad thing. Clamp it too loosely and you'll have it spinning about- a bad thing. Look up the torque specifications for mounting tab devices and you'll see that a large screw isn't necessary. So, proceed with caution, or tap the correct sized holes.
CH
I used to be an audiophool like you but then I took an arrow to the knee. |
#4 |
What about the effect of vibration ?
Surely it cannot be good for the wires bonded onto the die ? |
#5 |
What vibration? We try not to ad mechanical noise either(Vibration), do you have your electronics on the top of your sub box?
The wire bonds are "encapsulated" in plastic. They won't vibirate. Your caps are wraped plastic and foil, they potentially are subject to vibration. ![]() BTW, I have also enlarged the TO-247 pkg holes to #6 (USA) screws 100's of times without any problem. I like #6 screws better but, be aware of torque specs and use a big or springy washer or both. Nelson has had good luck with clip hold-downs also.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#6 |
Thanks for all of the input! I appreciate it very much!
Eric |
#7 | |
Bahco – True professionals’ love for increasing their performance by its ergonomics and design |
#8 |
The idea to use a file, is sure good.
To recommend Bacho is however not. They charge the same as Pferd, but the quality of Pferd files is quite a bit better. PFERD Needle Files Magura
Everything is possible....to do the impossible just takes a little while longer. www.class-a-labs.com |
#9 |
Another excellent suggestion - Thanks!
Eric |
#10 |
the To247 has a 3.1mm to 3.5mm diam hole. It is tapered
I have drilled many of these to 3.5mm for M3.5 mounting screws. The plastic on the back face often breaks away leaving a small circular indent around the enlarged hole. I see no problem with this M3.5 mounting. I have drilled a few To264 to 4mm, but I was a bit wary of this modification. Experiment on a few damaged ones first.
regards Andrew T. |
| aleph1.2 IRF240 vs IRFP250 | klimo_67 | Pass Labs | 20 | 8th April 2010 02:17 PM |
| new ampli with IRF240 | xcicc | Solid State | 23 | 29th May 2009 05:49 AM |
| IRF240 for sale please see link | dhole | Pass Labs | 1 | 18th July 2005 05:01 PM |
| Can i substitute IRF540 with IRF240 ?? | hifi | Solid State | 5 | 20th March 2001 06:50 PM |
| Page generated in 0.09730 seconds (83.41% PHP - 16.59% MySQL) with 10 queries |
