Old 7th January 2010, 06:31 PM   #1
Eric is offline Eric  United States
Eric's Avatar
Default Resistor for Amp output testing
Is this a good resistor to use with a completed Aleph-X amp to test power output and look for clipping behavior with a scope?
16 ohm 120w wire wound resistor
I was planning on getting 4 of them. I could put 2 of them in parallel for an 8ohm resistor and 4 of them in parallel for a 4 ohm resistor.
Thanks,
Eric
Old 7th January 2010, 06:38 PM   #2
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Thanks,
Eric
Sounds like a good plan. I have some of these myself, they're quite rugged and still go on happily after you have fried your whole hand trying to move them under heavy load
They may be very slightly inductive but for testing purposes that isn't an issue. How much power can an Aleph-X deliver, max, steady-state?
jd
/Another new issue: Linear Audio Volume 3!
Old 7th January 2010, 06:41 PM   #3
Eric's Avatar
I'm building a set of them that will likely run 100wpc into an 8 ohm load and 150-160w into a 4 ohm load. Thus, putting multiple resistors in parallel will also boost their power handling capacity.
thanks!
Eric
Old 7th January 2010, 07:37 PM   #4
The one and only
Nelson Pass's Avatar
I have a bunch of those. They work great.
Old 7th January 2010, 07:47 PM   #5
Eric's Avatar
Excellent! Thank you, Nelson!
Old 8th January 2010, 12:38 AM   #6
eyoung is offline eyoung  Scotland
eyoung's Avatar
Do not forget capacitance across Rload...However I have not done this looking at my amps on the O'scope I have read it makes a difference in the scope pattern and is more like the actual load.
That being said good luck and let us know your results.Oh Yeah be careful those resistors get really hot, burning fingers do not feel or smell good...
Regards, Elwood
"when you open your mind to the imposible, soon you will find the truth...."
Old 8th January 2010, 12:59 PM   #7
Eric's Avatar
Hmmm.. How much capacitance are you supposed to add? I've never heard this before...
After getting two warnings about burning my hands, I'll be sure to use oven mits or at least screw the resistors down to a board.
Old 8th January 2010, 01:29 PM   #8
janneman's Avatar
[snip].
The idea is that a real speaker load often represent a complex network not of just a resistor but also capacitors and/or inductors, and that even varies with frequency....
Especially the capacitive part can sometimes provoke an amp into instability/oscilations.
So, to check the power output of your amp in various steady state loads, the resistors are fine.
If you also want to verify amp stability, try paralleling those resistors with capacitors varying from perhaps 10nF through 100nF, 1uF, 10uF. Especially the latter is hard on the amp with high frequencies because it represent a low impedance, so you probably don't want to do that longer than just a few secs. Always slowly turn up the signal and watch the scope for funny patterns, turn it off if you see that!
Let us know how it goes!
jd
Old 8th January 2010, 01:36 PM   #9
jackinnj's Avatar
Mine are a bunch of Dale's that I bought at Electronic Surplus in Cleveland -- I use 5 50Watt, 40 Ohm -- mounted on a piece of spare pcb material. When I was testing the bridged LM4780 article for AX I accidentally placed the "tester" on a scotch tape dispenser -- and it melted the plastic onto my workbench.
Probably a good idea on settling on a connector scheme at the same time. While banana plugs are most frequent, you might also want to consider those times when you'll use pin plugs for old amps with those push-in speaker connectors.
Sometimes you'll see Heathkit dummy loads for audio on Ebay. I used a Heathkit "Cantenna" back in the ham radio days -- filled it with salad oil if I recall correctly. Oh, salad oil does go rancid after a while \m/
Old 8th January 2010, 01:54 PM   #10
Eric's Avatar
Thanks for the tip on caps and a hook-up scheme! Much appreciated!
I'm not ready to do testing just yet, I'm probably a few weeks away from that yet. PCBs are populated, Fets are matched, I'm now waiting for heat sinks to arrive so there is still some work to do.
Thanks!
Eric
Resistor Sound Testing DragonMaster Everything Else 18 2nd February 2006 11:34 PM
DRV134 Input Resistor & Opamp Output Questions Devil_H@ck Chip Amps 10 16th September 2004 10:24 AM
Testing Leach Amp, questions about output wigginjs Solid State 2 10th July 2004 11:07 PM
Resistor testing and directionality Bobken Everything Else 29 18th February 2003 10:42 PM
Resistor Directionality and testing gpapag Everything Else 18 18th February 2003 04:32 PM
Page generated in 0.09133 seconds (89.17% PHP - 10.83% MySQL) with 10 queries
