Simple Circlotron with Lateral MOSFETs
Old 18th May 2011, 12:53 PM   #21
juma is offline juma  Germany
juma's Avatar
You can't expect a single, 200mW JFET to drive couple of Volts into 390R load...
If you want to use buffer and SE2BAL convertor from post #1 just change R19 and R21 to 3k3
Old 18th May 2011, 01:01 PM   #22
GuidoR is offline GuidoR  Italy
GuidoR's Avatar
There's no free ticket...
many thanks
Guido
Old 17th May 2014, 05:12 PM   #23
vilfort is offline vilfort  United States
Default Turning this into a hybrid
A differential amp/driver stage can easily be built using 3 triodes like say 6sn7. Keep the output stage with the SK135 source followers. Then add a Mullard-like front end albeit with 3 triodes. Grounded cathode first. Then directly coupled into a long tailed pair. Each of the plates connected to the signal caps on the MOSEFET gates. Simple and sounds great. True midrange magic. No feedback.
D.
Old 26th June 2014, 09:12 PM   #24
marktmeyer is offline marktmeyer  United States
Vilfort, I have read as much as possible of your work, and was wondering what your present take is on the Hybrid Hafler mods. I am interested in doing a tube front end to either my DH500 or one of my DH200s. Have you ever done a pc board for the tube portion?
Old 6th March 2015, 08:15 PM   #25
drazen is offline drazen  Croatia
Hello everyone,
Finally I decided to make this Juma circlotron and I can say that this sounds really great. At first it was a little problem with the layout of the wiring and unstable DC offset and the current through the output MOSFET. Now everything is stable and is a great pleasure to hear the presentation of the sound of this amplifier.
I am very pleased and grateful to the constructor on the project.
PS. Cubie will wait a while to build.
Old 6th March 2015, 11:54 PM   #26
juma's Avatar
Hi Drazen,
congrats on your build, I'm glad you like it !
Talking about Cubie - I got a new circuit simmering, it'll be ready in a month or three...
Old 7th March 2015, 06:29 AM   #27
Thank juma,
cirklotron after the trial period need housing, front, rear and top plate, which are now under construction.
Following the theme Cubie
Old 25th May 2015, 05:53 AM   #28
stein2 is offline stein2  Serbia
stein2's Avatar
I'd like to add a small contribution here. Built one of these but as a completely different beast with E88CC in gain stage instead (with a lot of help from Juma and Zen, to be noted) and later needed to figure out is there any difference in sound between the original and the hybrid version, so, built one more, this one, but as I didn't want SE on input, tried a bit different approach. It works fine (huge understatement) but I usually say "fine" when I can't find anything that would bother me. On the attached images the fulldiff sch. of the gain stage, one messy image of the amp and where it's used. This amp is the black one at bottom with the big VU meters...
"Calculations? We don't need no stinkin calculations! We just make them really big!" - Papa
Old 21st February 2018, 08:55 AM   #29
coolnose is offline coolnose  Europe
coolnose's Avatar
Juma,
could I use your SE2BAL from the schematic using J271 (maybe in //) by "just" inverting the supply voltages ?
Thanks in advance for your comment.
Max
Old 21st February 2018, 09:15 AM   #30
juma's Avatar
It should work with P-channel JFET (J271 with inverted polarity for buffer cell) but I'm not sure if it's worth the effort - lower gm, wildly varying Idss, different transfer curve....
You'll have to test and experiment a bit...
Please don't use private messages for question related to audio projects. It defeats the purpose of the forum.
Simple Circlotron with Lateral MOSFETsHide this!Advertise here!
Lateral Mosfets for sale Fanuc Swap Meet 20 28th March 2009 10:17 AM
Substitute Lateral Mosfets joensd Parts 33 21st December 2008 01:57 PM
Lateral mosfets - why ? Stormo Solid State 5 2nd July 2003 07:14 AM
Lateral Type Mosfets Diogo Solid State 4 30th September 2002 08:11 AM
