I have already built the F5 as per original schematics. I like the sweet sound of the amp for moderate listening levels but I would like to get more power and more voltage gain while keeping it simple (like the F5). I saw some posts on making the F5 balanced X amp but it is not my goal. This is the schematics I came up with to get about 80-90W rms (8 ohms). The heatsink size would allow about 10Wrms (8 ohms) class A and the rest of power in class AB. It has a cascode input to handle higher voltage rails. It has a mosfet driver stage to increase the drive current (35ma) for the 4 pairs of mosfet outputs. This vertical mosfet driver also allows to get more gain from input stage (higher drain resistance) at the same time because of the high threshold voltage compared to lateral mosfet or BJT... To keep enough feedback factor while increasing the voltage gain to about 26db, the open loop gain is increased by paralleling output mosfet and modifying the input stage bias (3 ma). Can you comment if this design has some potential... Thanks Fab |
#2 |
seems like a possible way to go.
I'd not want to use any bipolar transistors myself... Of course it is no longer an F5 at this point. Where are you picking up the extra gain... maybe you can post the gains per stage (OL)? Is it all in the cascode? _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#3 | |
Most of the extra gain comes from the added parallel mosfets where the mosfet in common source configuration has a gain of about RL * gm where RL = 8 and gm = [5 -7] for IRFP240/9240. Thus each added pair adds about 5 of gain or so. Thus if 3 pairs gives about 15 of gain than it corresponds to the loss of feedback factor due to the closed loop gain increase from original F5 design... The cascode should not add much gain but the Rload of the jfet input is increased by reducing the Id and having the VGSoff the IRF610(9610) requiring more voltage drop across Rload. Yes it is no longer an F5 but can it provide good sound (at higher audio level)even if different? I wonder if only 3 pairs with higher bias would provide better sound than with 4 pairs... Also, regarding the cascode with bipolar, is my "floating" reference a good idea? Thanks Fab Last edited by fab; 28th December 2009 at 09:54 PM. Reason: explanation on added gain |
#4 |
Like this cascode:
#5 |
The one and only
The placement of the limiters will probably blow out the
drivers. Probably better to just take the limiters out.
#6 | |
thanks Fab |
#7 |
1 ohm Hmmmmm
.... i can test for you ..... |
#8 |
#9 | |
The one and only
of current, and you are more or less shorting their Sources to the rails. Current will flow, sparks will fly.
#10 | |
![]() Do you mean that if the current limiters are activated one day than I could blow off the M9 and M10 ![]() Thanks Fab |
| What's the Idle Current of the F5 Power Amp | NV&H | Pass Labs | 56 | 3rd February 2010 10:56 AM |
| What type of Relay for a power amp? Electro-mechanical? | Brit01 | Solid State | 8 | 11th August 2008 02:46 PM |
| if I have an amp with less 15W of power, what type of speaker would you recommend? | jarthel | Multi-Way | 17 | 6th July 2007 09:21 AM |
| Higher power amp PCBs for pro audio? | massappeal129 | Solid State | 2 | 10th February 2003 12:24 PM |
| Super-power amps - higher current better than higher voltage | Circlotron | Solid State | 34 | 28th June 2002 04:01 AM |
| Page generated in 0.11686 seconds (78.23% PHP - 21.77% MySQL) with 11 queries |
