#21 |
Okay, I guess I got phase margin wrong too.
I was quoting the margin where the open loop gain equaled 1 (0dB) and the phase margin is the difference between the phase and 180 degrees phase shift at the frequency where the closed loop gain and open loop gain are the same. This preamp has a closed loop gain of 18dB and at the open loop gain is 18dB at 3MHz. The phase margin is 360 deg - 330 deg, that is 30 degrees. Phase margin - Wikipedia, the free encyclopedia And wiki says it should be 35 deg. But since this isn't a power amp driving a capacitative load, 30 deg should be okay I think.
My Website: Hyperacusis, Tinnitus, My Story |
#22 |
Paper mache horn fabricator
Thanks for the Wiki info on feedback and phase margin, Johnloudb. I usually rely on degeneration for feedback--think I'll stick with it as it seems to work fine for me.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com |
#23 | |
Here's the open loop response when using the LSK170C JFETs and it has almost 80 degrees phase margin. I get slightly better simulated performance with the LSK170C also, but the difference is very slight and probably doesn't mean anything in the real world. But it looks like the more stable of the two, in this circuit anyway. I've used the LSK170C in my last preamp and it sounds really good, so I may stick with those if I can get my hands on some more.
![]() Quote:
My Website: Hyperacusis, Tinnitus, My Story Last edited by Johnloudb; 23rd December 2009 at 06:10 PM. |
#24 |
More like this (R11 and R20 are the source degeneration resistors):
#25 |
Looks nice Carpenter!
I made some modifications to my circuit to increase the phase margin using the bf862, now it is just above 50 degrees. So, I hope this works as good as the sim, since I'd like use that transistor. Any opinions about transistor matching in a circuit like this? I don't think it's really necessary, as long as they are reasonably close, but if there is a benefit I'll buy enough to match them. ![]() Open loop response. ![]() 10 KHz square wave.
#26 |
R2 is actually 90k for a closed loop gain of 18dB, not 70k like shown in that schematic.
#27 |
Well, I found the real problem with my circuit. I had all the gates on one channel wired to the sources and the gates on the other channel wired to the drains. Could that cause a problem???
![]() I just had the 220 ohm resistors lined up wrong on the generic PCB, and I just never thought about that possibility, and never checked that out. But while checking for continuity of the JFET mounting pads, I found the shorts. Got to check everything!!! Oh, well, at least the preamp will be more stable now.
#28 |
Ooooooh.... that does add an interesting wrinkle to the mix. Good luck with the next attempt.
#29 |
#30 |
Triple check; check at different times in the day.
Make us proud!
| Cascode question | woody | Solid State | 1 | 20th May 2008 11:50 PM |
| folded cascode | the_tool | Chip Amps | 1 | 27th June 2006 09:53 PM |
| Hybrid Cascode ? | Eli Duttman | Tubes / Valves | 3 | 9th May 2006 11:35 PM |
| Boz | RobPhill33 | Pass Labs | 3 | 13th January 2003 05:28 PM |
| BOZ | ding | Pass Labs | 4 | 25th November 2001 10:52 PM |
