Cascode BOZ
Cascode BOZ
Old 21st December 2009, 06:32 PM   #11
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Cascode BOZ
There's a mistake somewhere, and the JFETs are croaking
either from overheating or more likely high voltage.
I bet oscillation, if you don't have a scope.
You don't have a resistor in series with the output, and the
value of R1 might be too low.
Old 21st December 2009, 09:37 PM   #12
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
Cascode BOZ
R1... Yes, we generally use 100 to 220 ohms. I miss that one altogether.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 22nd December 2009, 12:16 AM   #13
Johnloudb is offline Johnloudb  United States
Johnloudb's Avatar
Thanks for input for all the input guys!
Originally Posted by juma
The Vgs of your JFETs got positive (gates got higher potential than sources).
The possible causes:
- the output coupling cap is leaking;
- you don't have a resistor (100k - 1Meg) from the point where all the gates meet to ground;
- you connected somethnig a wrong way.
Thanks, I've been investigating the circuit more carefully, and it does appear the JFETs are toast. Just to double check I put a 9v battery across them again with input grounded and they are each pulling 18.0mA through drain and 12uA through the gate. Should be 9.1mA. And, it's highly unlikely do to electrostatic damage given that I haven't killed one yet on my test board (below).
Cascode BOZ-jfet_testboard-jpg
I neglected to put any load at the output when I fired it up. That may have affected stability, or maybe a transient voltage at turn on damaged the JFETs. Don't know.
Originally Posted by revintage
Anthing wrong with the manufacturers, NXT, model?
I didn't look too hard I guess. Thanks for the model.
I'll start over, do some spice sims and hook up the circuit without feedback first and see if how that goes. And, I'll be sure to put, say, 20k load resistance at the output.
I used a 49.9 ohm resistance for R1 because in another cascode circuit using the IRF510, putting a larger resistance there caused a large peak at 10Mhz, I think. But, I'll do some spice sims and see what happens.
I'll put a 220 ohm resistance at the output too.
Thank You.
My Website: Hyperacusis, Tinnitus, My Story
Old 22nd December 2009, 07:26 AM   #14
revintage is offline revintage
But I suppose you had the 10k from output to ground connected. Otherwise this might be the cause as it is also the ground-reference for the jfet gates.
Old 22nd December 2009, 07:41 AM   #15
carpenter's Avatar
Cascode BOZ
Which begs the question: if you remove the feedback loop, will you provide another ground reference for the jfet gates?
Old 22nd December 2009, 08:03 AM   #16
A 470k from the JFETs gate to ground could do no harm.
Old 22nd December 2009, 12:40 PM   #17
Johnloudb's Avatar
I had the 10k at the input grounded, but I didn't have the 10k ohm load at the output. So, I agree that this is likely the cause of the problem.
I see what you mean about that being the ground reference for the JFETs.
I'll add that 470k resistor while I'm at it.
Old 22nd December 2009, 09:14 PM   #18
The one and only
Cascode BOZ
The circuit should not require an output load for stability.
Old 22nd December 2009, 09:51 PM   #19
IŽd say the output resistor wether it is 10k or some other value is absolutely necessary, but not for stability. This to still have a ground-reference for the JFET gates in case you remove the source. But as I suggested before you could also add a resistor directly from the JFETs gate to ground to get this.
Old 22nd December 2009, 11:28 PM   #20
Johnloudb's Avatar
Okay, good to know!!! I didn't think so at first either (hence no resistor), but not sure and I'm kind of stumped here.
Here's the circuit schematic again but simmed with the bf862 JFET model. I added a small cap to get rid of a response peak at 1MHz. I added the 220 gate stopper to the MOSFET, which had no affect on the response in this circuit.
Cascode BOZ-cascode_boz_bf862-png
Here's the simmed high frequency open loop response and shows almost 20 degrees of phase margin. That's not really very good though is it?
Cascode BOZ-c_boz_openloop-png
If this all looks okay, I'll go order some more JFETs.
Cascode BOZHide this!Advertise here!
Cascode question woody Solid State 1 20th May 2008 11:50 PM
folded cascode the_tool Chip Amps 1 27th June 2006 09:53 PM
Hybrid Cascode ? Eli Duttman Tubes / Valves 3 9th May 2006 11:35 PM
Boz RobPhill33 Pass Labs 3 13th January 2003 05:28 PM
BOZ ding Pass Labs 4 25th November 2001 10:52 PM
