Old 20th December 2009, 05:41 PM   #1
adusson is offline adusson  Finland
adusson's Avatar
Default Aleph 1,5 ?
I have built two monoblocks wich is something between Aleph2 and 1,2.
Works really great and sounds wery good.
Each monoblock uses 600W continosly(2,62A 230V), rail is +-51V, so the get really hot!
Capasistors are Rifa 4x100 000uF and 18pcs. irfp 240 in each amp, trafos are an 11kg 800VA Toroid.
Here is what they look like:
Bort med moms på dill, NU!!
Old 20th December 2009, 05:47 PM   #2
valo is offline valo  Norway
valo's Avatar
nice work, have you measured the temperature?, I measure about 70 degrees on the transistors on my diy Aleph 5
http://www.polarboing.com
Old 20th December 2009, 05:51 PM   #3
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
monsters!
Old 20th December 2009, 05:53 PM   #4
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
very nice - but you need at least another one 800VA Donut per monoblock ;
800VA is too small for 600VA consumtion
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 20th December 2009, 06:13 PM   #5
tortello's Avatar
Congratulations,
I like your "monsters" very much, and your Triumph ST too!
(even if it is not a Monster!) : D
Marcello
Old 20th December 2009, 06:14 PM   #6
adusson's Avatar
Ok, but I think these trafos does the job anyway, here is a link for some more info about the transformers...
https://www1.elfa.se/data1/wwwroot/w...A/05613997.pdf
and
Toroidal core transformer for audio amplifiers 800 VA - ELFA tehnikapood
I have compared with other transformers wich i 1000VA an the weight i only around 7kg, mine is 11kg...
Old 20th December 2009, 06:26 PM   #7
Gyuri is offline Gyuri  Hungary
Gyuri's Avatar
Very good implementation. I like it because of that Aleph configuration, because ( availing itself of a computer technology terminology) can be scalable configuration.
I mean you build the size that your cooling flange and your power-supply unit allow out of it. Fundamentally sure money question.
It's mine:
My good old-new Aleph
Gyuri
Those who would have deserved the life they are all dead already. "Oh, my dead dears!" - Captain Cat
Old 20th December 2009, 06:46 PM   #8
adusson's Avatar
It's mine:
Gyuri
Thank you for your reply, your amps could almost drive a nuclearplant...
Old 20th December 2009, 07:30 PM   #9
osscar is offline osscar  Latvia
osscar's Avatar
Yes, these are very good transformers, silent as the tomb, and no vibration. It was quite expensive ...
Your amps is also perfect. I also thought about building a new amplifier just can not decide BA-1 or Aleph
Old 20th December 2009, 07:39 PM   #10
Zen Mod's Avatar
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.13602 seconds (68.46% PHP - 31.54% MySQL) with 11 queries
