Old 18th December 2009, 10:16 PM   #1
Default aleph 2 help
hello to everyone
i have just finnished some kk pcb aleph 2 and have read about leaving r19 out of the circuit to raise the bias
in an aleph 2 this is the 1k is this correct ? and the 56k2 r 17 still gets installed ?
how crucial is the 56k2 value can i use 56k instead without hurting my amplifier
cheers from jason
Old 18th December 2009, 10:45 PM   #2
MEGA-amp's Avatar
R19 is referencing Pass Labs schematic, It's the 56.2K resistor. It trims DC bias. I just leave it out altogether, bias will generally increase by 500-600mA overall.
Old 19th December 2009, 04:59 AM   #3
The one and only
Nelson Pass's Avatar
Yes, it's used for cases where the circuit does not have
quite as much heat sinking as you might want. You
can trim the bias down arbitrarily without screwing around
the ratios of other values.
Old 22nd December 2009, 11:01 PM   #4
hello fellow diy,ers
thankyou for you advice mr pass and mega
i have left r19 out and the mono blocks are running great so far
both are around .18 mv offset and the bias is .6v across the source resistors
one side of one mono block is .5v though for some reason ,how might i correct this ?
the output devices are well matched by tech diy store and the irf920 are also matched triplets so what could cause this
other than the small bias difference on one mono block they are playing great and sound magnificent
they are built as aleph 2 but run on aleph 5 voltage they run between 55 to 63 c temp depending on outside temp and are dead silent when switched on
cheers jason
Old 23rd December 2009, 10:51 PM   #5
The one and only
You can try trimming the resistor value coming off the Drain
of the input transistor to the - rail for that much offset.
Old 25th December 2009, 09:54 PM   #6
hello nelson
i am very greatfull to you for being able to build this amp ,the more i am listening to it the more it is impressing me
any hints on how much to trim that ressistor ?
a starting value perhaps
cheers jason
Old 26th December 2009, 03:27 AM   #7
The one and only
Try a larger a larger value. If the original is 392 and gives
you +.5V, then try 475 ohms.
Old 26th December 2009, 08:20 AM   #8
thankyou mr pass
i will give it a try
cheers jason
Old 29th December 2009, 07:27 AM   #9
gianc is offline gianc  Canada
Default Same question for Aleph 5
I would like to try high bias on my Aleph 5, currently I have 221K for c19 and heat sinks are not that hot. When you say to leave out r19 does that mean I can snip one side of r19 and it open, or are you supposed to jumper r19 as I have read in another post (Top ten ways to a better Aleph).
Old 29th December 2009, 12:07 PM   #10
MEGA-amp's Avatar
leave it open
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 13 27th April 2012 02:13 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 17 9th January 2012 02:10 PM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
WTB: Aleph-mini PCBs and transistor set for Aleph 30 needtubes Swap Meet 4 6th November 2005 06:29 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.08931 seconds (78.99% PHP - 21.01% MySQL) with 10 queries
