hi,
i want to build an F2 (or should that moniker be reserved for the originals made by the big man himself? i should say F2 clone). i have a question regarding the PSU. the original schematic in the service manual shows a toroid with dual 18v secondaries. can replace this with two 0-18 EI transformers? is it possible to use a single, centre tapped EI transformer? i am asking because toroidal transformers are very expensive in india, about 2.5x the cost of a good EI transformer. if i use two transformers i am thinking of going with 350VA each. do you think i need to increase this? thanks mymindinside |
#2 |
according to my tricky memory - F2 have 75W dissipation per channel , so even 250VA xformer per channel is approaching overkill ...... but more is always merrier , at least in xformer department ;
you can use CT xformer - connecting CT to gnd and using just two diodes (one from each sec. end to + ) to have full-wave rectification or even better - use two xformers ( from 250VA and up) , each having just one 18Vac secondary Papa's PSU is sort of dual mono PSU with common core and primary
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
thanks Zen mod,
if i go with two transformers (which is not more expensive for me than going with one, larger one) what type of rectification would i use? a bridge with the - connected to ground? Also, with this xformer size, will i need a separate soft start circuit aside from what is already in the schematic (in the form of the thermistors)? Last edited by mymindinside; 12th December 2009 at 11:10 AM. |
#4 |
Going out to buy the parts today.
was a bit confused about how to connect the thermistors...do they go across the primaries?or in series with the primaries? |
#5 |
The one and only
If you are building an F2 then you will definitely want to
acquire a pair of the SemiSouth Jfets the next time a group buy occurs. Just drop them in, adjust the offset, and be happy.
#6 |
Hello Mr. Pass,
thank you for the Info. Are there more useful mods for the F2 + SemiSouth Jfets? Happy X-mas to you and your familiy! Maybe you have a small gift for us DIY'er ? With kind regards Sam Greding / Bavaria |
#7 |
hello Mr Pass,
will definitely try the Jfets once the amp is up and running. my enthusiasm has taken a hit in the past few days though, when i was told in another thread that none of the heatsinks i have available are good enough for the F2. just to confirm, the dissipation is 75w for 2 channels? apparently the heatsinks i posted did not have a thick enough base so the thermal conduction from the device was effective only across a small area. ![]() i would really appreciate it if you had a look at the thread and shared any insights, and of course, merry christmas to you and your loved ones! mymindinside p.s. the thread is located here |
#8 |
I read the thread in regards to the heatsinks you are looking at. One thing you can do to help spread the heat more evenly across the heatsink would be to attach the mosfet directly to a piece of copper that covers most of the flat face of the heatsink. Then put the insulator between the copper plate and the aluminum heatsink. Copper has a higher thermal coefficient, so it will pull heat away from the mosfet (or any other device) quicker. And having the transistor tied directly to the copper, then isolating the copper pulls the heat from the transistor faster.
Peace, Dave |
#9 | ||
you can use one NTC for both xformers Quote:
![]() I wrote already - 75W per channel
#10 |
uh oh, sorry
thanks for the patient help mymindinside |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| Look Transformers | jaudio | Chip Amps | 56 | 26th March 2007 01:21 AM |
| Help With ESL Transformers | ak_47_boy | Planars & Exotics | 21 | 19th January 2007 11:20 AM |
| Back to Back transformers as Isolation transformers | mikee55 | Chip Amps | 2 | 17th March 2006 11:38 AM |
| Would these transformers be of any use to me? :D | SkinnyBoy | Solid State | 14 | 9th June 2003 11:35 AM |
| Page generated in 0.10395 seconds (83.72% PHP - 16.28% MySQL) with 11 queries |
