Pearl Two - Page 83 - diyAudio
Old 22nd August 2011, 02:11 PM   #821
richluvsound's Avatar
I did read somewhere else about the low gain of the Denon . I also don't really have the experience to start getting to clever with changes .
I'll look around for the Dynavector .I have a few contacts here for the that sort of thing .
I noticed my name on the list for the Salas reg . No rush . I might have it finished in time for the Christmas carols. I have an amp project that has taken
priority.
Rich
Old 22nd August 2011, 02:11 PM   #822
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
Rich,
The Takman and Holco should be on your list, especially the Holco, if they are the original with non-magnetic bodies and leads.
Here's the thing though, in a critical area, like the load resistor, you might want to try something more transparent, like a Charcroft Z-foil bulk resistors. (Other will disagree and feel it is not necessary.) We call them the Nake Vishay Z-foil resistors around here. They are expensive, but there is suppose to be nothing better. I have some for a simple preamp, but haven't had the chance to use them yet.
Cool thing is, once you settle on the value, you can swap them out to see if you get an improvement or not.
I've heard and read good things about Grado, the Blue Note No. 2 and Shure Shure M97xE 2 and Benz Micro. These brands all have reasonably priced carts. I use the Denon 103R. The difference between the 103 and 103r is the purity of the copper winding; the R is better. Mine is outfitted with a Soundsmith ruby stylis and Midas aluminum. However, I won't see the benefits of this cart until I build the Pearl II.
Have fun and good luck!
Vince
I build, therefore I am.
Old 22nd August 2011, 02:26 PM   #823
Cheers Vince ,
the Takman are half the price of the Dales ... Save some for the Charcrofts you fancy .
As I'm ordering for a balanced B1 and the Pearl 2 saving a little is always nice .
Rich
Old 22nd August 2011, 02:29 PM   #824
vdi_nenna's Avatar
saving a little is always nice.
Nothing wrong with that; just so long as you know that the alternatives exist.
Old 28th August 2011, 07:11 PM   #825
On one of my boards I'm seeing unstable voltage at R17. It drifts 2-300 mv after a short time. Should I replace P1?
Old 29th August 2011, 08:06 AM   #826
nar is offline nar
nar's Avatar
Did you implement C7 ? Wayne stated that boards finally wouldn't need them, especially if you use ZVP3310 and Pearl II original layout ...
It would give some instability problems to some users if I recall.
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 29th August 2011, 04:27 PM   #827
I did implement C7. I'm using ZXP3310 in Q2, and I assume I'm using the original layout. I'll pull C7 tonight and see if it helps.
Old 30th August 2011, 09:39 PM   #828
nAr
C7 is removed and voltages are stable now
I also implemented your ground scheme by grounding the outputs to the PS ground, isolated from the case, and grounding the case to earth.
Mark
Old 31st August 2011, 06:40 AM   #829
nar is offline nar
nar's Avatar
So it works fine, good
Old 31st August 2011, 11:20 AM   #830
Yes, it's a fine sounding unit.
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
