#801 |
Thanks nAr. That works much better, but I'm still seeing some hokey voltages. I'm getting +24 / -27 from one board, and +22.75 / -27.8 on the other. I'm checking at the output pins of the regs and the ground pad.
But holy God, do these boards sound good . Mt current phono pre is a Hagerman Bugle, and the sound coming out of these Pearl boards is fantastic. I could only use one at a time, and just played a single track a few times on each, but it was obvious my analog rig is at a whole new level.I already ordered new regs just in case. Should I change out the three that aren't putting out 24v? Also, do you still recommend this PS for the Pearl 2? http://www.amb.org/audio/sigma22/ Mark Last edited by McQuaide; 17th August 2011 at 12:22 AM. |
#802 | ||
![]() Quote:
Best, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
#803 |
I had about a 10 dB difference in gain between L and R channels in a Pearl I built. After I got some help on this forum, I ordered 8 matched 2SK170BL JFETs from FETAUDIO out of Hong Kong, which were very reasonably priced. I replaced all the 2SK170BL JFETs with the new parts, and now channel balance is spot on. I guess my original FETs were poorly matched. Many thanks to FETAUDIO.
This is a very good sounding phono stage. It is impressively quiet. Incredibly quiet! Thanks to NAR and others for the help. Last edited by milosz; 21st August 2011 at 03:21 AM. |
#804 | |
#805 |
Gents ,
Can I use 47.5 k instead of 47k ... same question ! 6.81k instead of 6.8k ? cheers , Rich |
#806 |
I checked the voltages on my Pearl 2 boards to see how they compared with Wayne's. Everything seems reasonably close, with the exception of the collector terminal of Q3 (connects to R11). I'm seeing 14.7 - 14.9 volts there, while Wayne's drawing shows 10.1v. I'm not sure if this signifies anything.
Mark |
#807 |
diyAudio Chief Moderator
Has to do with pinch off voltage in different batches that give differences in DC bias. Combined transconductance of the quads should be near over a wider IDSS range, and the 10R resistors equalize a lot. I would be worried only about gain differences in the AC output and then look for problems.
#808 | |
#809 |
Run a test record with a tone 1kHz or preferably lower, put your DVM on ACV and probe the output RCA. Most DVMs will catch such tones well. HFNRR test disc has 300Hz. See that the track has not advanced to higher modulation if your disc has no lock grooves when you will do the other channel for comparison. That will include your cartridge's channel matching performance.
#810 |
Thanks.
| Another diy-pearl... | lykkedk | Pass Labs | 18 | 15th June 2007 04:44 PM |
| ono or pearl PCB's | mantisory | Pass Labs | 1 | 28th September 2006 11:12 PM |
| Pearl need help | dzkh63 | Pass Labs | 1 | 26th September 2006 03:16 PM |
| WTB: Pearl PCB | aire | Pass Labs | 1 | 26th February 2006 10:51 AM |
