Pearl Two - Page 201 - diyAudio
Old 2nd March 2013, 12:30 PM   #2001
poli is offline poli  Germany
poli's Avatar
Wellerman and 6L6,
both of you many thanks, especially for the drawing!
I have to change my earth grounding in the PSU. So far I have only grounded the transformer and the chassis, but not the PSU (rectifier) itself.
The RCA jacks are insulated from the phono chassis and phono chassis has no ground connection, neither to earth wire nor to PSU chassis, so that should be ok.
Will modify my PSU now.
Thanks again!
Cheers
Poli
Old 2nd March 2013, 12:36 PM   #2002
Mine's slightly different (I didn't use the same PS). The phono ground and the unmarked ground pads on the Pearl boards are connected to the Pearl Chassis, which is not grounded to earth. The RCA jacks and power connections are the same as 6L6s, floating. The PS chassis is earthed for safety.
Also, I used 2 conductor shielded wire for the signal in and out. This hummed like crazy until the shield was connected to the RCA ground.
Old 2nd March 2013, 12:45 PM   #2003
rsavas is offline rsavas  Canada
Good stuff guys, grounding issues are fun wow!!
It would be nice for you to take note ACV of the output or even better yet an FFT plot. Great way to compare implementations &measured results
Test condition would be with inputs grounded, usnig a true RMS meter. If you have weighting filters, try them out as well.
Cheers
Rick
Old 2nd March 2013, 01:45 PM   #2004
I just put a multimeter on mine, and it shows .000v AC with the inputs shorted. I'm not sure if that means anything.
Old 2nd March 2013, 01:55 PM   #2005
Well it means that the noise is so low that your meter can not measure it, which is a good thing. Thus for you, the noise is in the micro-volt range as it should be.
I am assuming that you have a regular DMM, which usually have limited audio BW, so that would make the noise BW less. Okay if hum is the dominant source, but it is not in your case since you are not the one having hum issues.
Old 2nd March 2013, 03:48 PM   #2006
Is there any problem with a power cord from the power supply to Pearl 2 board that is 4, 5 or even 6 ft long? If so what is max? All I can really find related to the topic so far is the the power supply should be at least 3 feet away from the phono boards for quiet operation, can i assume that 4-5 ft is "better"? Asking because I need at least 5 ft for planned set up.
Thanks in advance,
Russellc
Pass B-1 preamp, Pass F-5 Amp, Pass F-6 Amp, Pass BA-3 Preamp, Pass BA-3 Amp, Pass M-2 amp, Pass Pearl 2 Phono
Old 2nd March 2013, 05:47 PM   #2007
6L6 is offline 6L6  United States
6L6's Avatar
Yes, longer is fine!
Old 2nd March 2013, 06:18 PM   #2008
Great. That is exactly what I was hoping!
Russellc
Old 2nd March 2013, 09:43 PM   #2009
Thanks in advance,
Russellc
Mine has got a 5ft braided cable between the psu and Pearl. I added 2 ferrite cores for just in case it might pick up hf noise. It seems to work fine this way.
Old 3rd March 2013, 02:50 PM   #2010
richluvsound's Avatar
Default Big Thanks !
Spent a few hours set up the my turntable and the pearl .....
Deeee licious ... !
Rich
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
