Pearl Two - Page 192 - diyAudio
Old 24th February 2013, 12:10 AM   #1911
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
whatever - it's better that way - carefully made Pearl to be OK , and easier to manage Bryston to be blamed
I'll find schmtc of their gain block ( shown as triangle - it's discrete OP , if memory serves me well ) and think what you can do , except cleaning balance pot
in your boots - I'll toss it (balance pot) out of signal route anyway ; connected like that , it's good only for Panorama function in mixing decks , not serious piece of good equipment
have you any chance for quick mock-up of "passive" pre ? when made correctly ( and in your case you don't need much gain , if any ) it can be more rewarding than mediocre gain solution
when I'm saying correctly - let's say that B1 is first in line of gadgets worthy of making
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 24th February 2013, 12:11 AM   #1912
Zen Mod's Avatar
and yes - Buzz and Jaccolina - buzz of
you'll not see me with t on end of nick
Old 24th February 2013, 12:24 AM   #1913
richluvsound's Avatar
Hi Wellerman,
its the Pro s Concorde . Not MM . Not Ideal ,but don't see much point in investing in better with this problem .
The balance pot has just had a squirt ,but problem persists ( it does work with other inputted components )
One of the side affects of the meds ... is a short fuse - feeling like chewing my own arm off . Maybe not the best place to be coming from .
I'm off to a friends next weekend - will take it with me and try it on his set up !
Old 24th February 2013, 12:28 AM   #1914
Hi Zen ,
" let's say that B1 is first in line of gadgets worthy of making
I'll look at by-passing the balance pot ....
B1 is sitting in the cupboard waiting to be finished .... need to get to it I guess
Rich
Old 24th February 2013, 12:39 AM   #1915
bnorrish's Avatar
Having trouble with my Pearl 2. Another dumb mistake - had a jumper on Cx.....I am taking break any going to listen to some records. Mumford and Sons "Babel" sounds nice, it will sound a lot better with a good phono stage.
Old 24th February 2013, 10:07 AM   #1916
Originally Posted by richluvsound View Post
Hi Wellerman,
its the Pro s Concorde . Not MM . Not Ideal ,but don't see much point in investing in better with this prp !
The Concorde Pro S has 5mV output, so the Pearl will amplify that to 2.5V. Most pre-amps should be able to handle that. Replacing the Concorde might be worth it, if only for the preservation of your vinyl, the recommended 4g tracking force is quite high.
Anyway, I think it is a good idea to test the Pearl on other equipent, could save you some frustration if the Bryston turns out to be the problem. But then I wouldn't understand why the problem is only with the Pearl. There is no problem with the balance all the way to the right?
Old 24th February 2013, 03:27 PM   #1917
Hi wellerman ,
thanks for the help .
The B1 is going to get finished- just need to order the transformer and a few bits for the chassis .
The cartridge is only used for testing ,but will go as I get the chance
I dont get any distrtion when balance to the right ..... just weirdness most sinister LOL
Rich
Old 25th February 2013, 02:35 AM   #1918
bnorrish's Avatar
Questions for the experts. I Still have one bad channel. Just very loud hum at moderate volume, no music.I had replaced all the ZTX450s (Q1, Q3, Q10, Q11) and the Q2 (ZVP3310).
- I can only get V down to 5.7 V at the “Set p1 for 0 V” pad at maximum adjustment for P1!
- All other voltages are good.
At this point I am thinking Q5 and Q4 is bad. What do you think? Should I replace Q4 and Q5 with matched pair of 2sk170s? The other channel is good, but should those be replaced as well to match? I have a matched quad of 2sk170s.
Old 25th February 2013, 02:41 AM   #1919
Zen Mod's Avatar
best way is to find ( i think it's somewhere in the thread ) schmtc with measurements in strategic points , then to compare , write down your voltages and post it here
sorry if you already made that , I'm sorta greenhorn in this thread
Old 25th February 2013, 03:09 AM   #1920
buzzforb's Avatar
Originally Posted by Zen Mod View Post
I'm sorta greenhorn
...Shape the sound , Man!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright 1999-2017 diyAudio
