Pearl Two - Page 182 - diyAudio
Old 18th February 2013, 04:28 PM   #1811
poli is offline poli  Germany
poli's Avatar
Hi Rich,
welcome to the club! Yeah, I am having similar experiences. I've been fiddling around with the Pearl 2 now more than a year and only have a very faint signal on both channels - strange that this happens on both channels at the same time. I made myself an "inverse RIAA" stage and checking the signal throughput with a signal generator and a small "inverse RIAA" signal, so that it simulates a MC cartridge, but so far no clue where the problem is. I re-soldered all pins again but that does not seem to be the problem. Voltages are also in range according to Waynes schematic. Anybody an idea what else to check?
Poli
Old 18th February 2013, 05:17 PM   #1812
richluvsound's Avatar
Hi 6L6 ,
I have changed cartridge . I'll check all the voltages again in the morning .
Just strange that distorted sound migrates from left channel to the other when the balance control is all the way to the left . The boards are separate -no physical way to short ????
Anyway , hope you and yours are well
Old 18th February 2013, 05:25 PM   #1813
6L6 is offline 6L6  United States
6L6's Avatar
That sounds like a cartridge wiring issue, perhaps.
Andrew is 3 and a bit, and talking up a storm. We should skype sometime, he will seem huge!
Old 18th February 2013, 05:42 PM   #1814
Yes , Skype soon
I need to borrow a TT . I did some messing around with phone cables ,so maybe I did my usual LOL
Rich
Old 18th February 2013, 09:16 PM   #1815
Originally Posted by poli View Post
Hi Rich,
Poli
I had one channel with a lot of noise (but also music) and changing out the ZVP3310 worked. Voltages were OK, but somehow the ZVP3310 wasn't. Have you put a jumper in the location of R15?
Old 18th February 2013, 09:43 PM   #1816
Hi Wellerman ,
was this post to me or Poli ?
Old 18th February 2013, 10:03 PM   #1817
bnorrish's Avatar
What clued you that ZVP3310 was bad? Did you measure ~ 10 mA current going into per Wayne's voltages diagram?
I used 10R instead of 10K on R7, R8 and R10. I think I get carried away stuffing all the 10Rs. After replacing them, found out that Q1 and Q3 were bad. Waiting for an order of ZTX450s. I only ordered 10.
Old 18th February 2013, 10:04 PM   #1818
Default Bad MOSFET
Check the 2nd stage MOSFET (ZVP3310). I had a similar problem and a bad ZVP3310 in the affected channel was the apparent cause.
Old 19th February 2013, 12:43 AM   #1819
In my case it was lower gain and much higher distortion in the right channel. My tech. Mike Missel found it with his distortion meter.
Old 19th February 2013, 12:48 AM   #1820
6L6's Avatar
I really want a distortion meter...
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
