Pearl Two - Page 171 - diyAudio
Old 12th December 2012, 02:07 AM   #1701
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
6L6, do you use 55 or 65 db gain with your 110? I using 55 db.
I build, therefore I am.
Old 12th December 2012, 02:29 AM   #1702
6L6 is offline 6L6  United States
6L6's Avatar
Ah... I said Pearl, not Pearl 2... I haven't actually listened to it all that much with the 2, as the original is sooooo perfect.
Old 12th December 2012, 02:35 AM   #1703
vdi_nenna's Avatar
I knew it and fell into the trap anyway!
Old 12th December 2012, 10:29 AM   #1704
poli is offline poli  Germany
poli's Avatar
Originally Posted by 6L6 View Post
It's minor, but there is a missing ground connection from the bridges to the caps. Here is a corrected drawing -
Thanks a lot, 6L6!
Cheers
Poli
Old 12th December 2012, 12:53 PM   #1705
vdi_nenna's Avatar
BTW- Anyone try a power cord other than a standard PC power cord?
I know this takes a back seat to so many other adjustments and tweaks. However, in 10 minutes, I made a simple power cord with 3-conductor electrical wire, Marinco and Watt Gate plugs. There was a nice improvement, particularly in the stability of the image. Also the sound stage opened up a bit more or it might just have been because the image was more stable.
Complex music became more interesting and less clouded.
Anyway, without getting to crazy about the topic, I'd like to hear your thoughts.
Old 12th December 2012, 12:58 PM   #1706
6L6's Avatar
With those kind of results, you should make a tricked-out umbilical as well! Nice!
Old 12th December 2012, 01:04 PM   #1707
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I use the less expensive Marinco models and even some Chinese knockoffs. they all offer better grip then any off the shelf stuff. Cannot hurt, and you have better control of quality of the contact and the wire. I also swapped my sockets for the red Hubbell hospital grade ones. It's not necessarily about sound improvement but better engineering for me.
Old 12th December 2012, 01:12 PM   #1708
vdi_nenna's Avatar
I did. It's a CAT5 umbilical. Uses a CB radio connector or 4 pin DIN from Radio Shack. Build quality of the DIN plugs is suprising. Has a screw down nut to lock in place.
Could probably find the same parts from Mouser or Digikey for half the cost, but didn't want to wait.
Whole embilical cost around $16, not including the CAT5 cable.
You can find isolated ground outlets at Home Depot. They are the ones that are orange and have a green triangle on the face of the outlet.
My friend pickup the same thing, but with a built-in line filter from McMaster Carr for somehwere between $50 and $60 each.
Pretty much the same stuff as hi-end outlets, minus the cryo and Tesla treatments.
Old 13th December 2012, 01:17 AM   #1709
vdi_nenna's Avatar
Can someone tell me if C22 is the cap used for MM loading?
Can it be removed for MC carts?
Thanks,
Vince
Old 13th December 2012, 01:27 AM   #1710
6L6's Avatar
Yes.
Yes. In fact, most cartridges have enough capacitive loading through the interconnect that you can ignore the loading cap altogether. As always, however, refer to the manufacturers recommendation to Resistive and Capacitive loading.
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
