Pearl Two - Page 169 - diyAudio
Old 25th November 2012, 03:08 AM   #1681
vdi_nenna's Avatar
Send a message via Yahoo to vdi_nenna
F5 on bottom and 5w SIT on top.
I build, therefore I am.
Old 25th November 2012, 03:11 PM   #1682
vdi_nenna's Avatar
Got up early to find the problem. Might have been the jacket on the 30 gauge output wire was soldered over.
That make any sense? I have a headache.
Also changed the parallel resistor to a 294 ohm, reducing the total resistance to 193 ohms for R14.
Subsequently, the output is about the same as my previous phono's MC setting.
The sound is real nice, even with no warm up. It has quite a bit more soul than my IC based phono.
Wayne, thanks for putting this great phono pre together, and to everyone for their support!
Vince
Old 25th November 2012, 10:50 PM   #1683
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Crisis averted, very good!
Old 30th November 2012, 12:29 AM   #1684
Default channel balance problem
I posted earlier about my balance problem and it showed up on the scope looking at the output mosfet, so I replaced it and they are spot on now.
I have to agree on the sound, it is more spacious and 3d than anything else I have had ( classe\threshold\crown\paracass ). a fantastic and educational fun piece, Thank You Wayne.
jjacks4x
Old 9th December 2012, 06:59 PM   #1685
vdi_nenna's Avatar
Default Problem with pearl power supply
Found the pearl II off this morning. Found that the ps filter cap had leaked.
Replaced with 50v 10k uF. Voltages seem to be off but from what I read somewhere, the circuit draws from the plus and minus differently.
Not connected to the circuit the ps gave 38v neg and 23v pos.
Connected to the circuit, had a reading of -50 and +7v at the ps caps.
Everything was quite, no noise and it sounded a bit better than before.
Unsure, I unplugged it and awaiting some advice on what could be happening.
TIA
Vince
Old 9th December 2012, 07:29 PM   #1686
6L6 is offline 6L6  United States
6L6's Avatar
Disconnect PSU from circuit and measure voltages.
Old 9th December 2012, 07:45 PM   #1687
vdi_nenna's Avatar
I did. Was getting +23v and -34v.
Also changed bridges, but made no difference.
Maybe it settled, I'll measure when I get home again.
Thx
Vince
Old 9th December 2012, 08:06 PM   #1688
6L6's Avatar
So did you get the erroneous voltage before or after the on-board regulators?
Oops - then I saw this...
Which means you have something miss-wired, if you have the full psu negative voltage at one of the rails.
I am looking at your PSU photos and am getting confused because there isn't enough resolution... Can you take a close, well-lit, in focus photo and post it here? Thanks!
Old 9th December 2012, 08:19 PM   #1689
vdi_nenna's Avatar
I'll check everything again.
The wiring colors will confuse you even more.
I'll check it carefully again. There's not much to it.
Old 9th December 2012, 08:36 PM   #1690
6L6's Avatar
I don't care about colors... I need to see the wiring - I think I see a big error in one of the photos but am not sure without more resolution.
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright 1999-2017 diyAudio
