Pearl Two - Page 165 - diyAudio
Old 20th July 2012, 02:36 PM   #1641
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Wellerman View Post
If everything fails I can still order the boards.
Or stick the boards in die-cast aluminum boxes.
President Dwayne Camacho says you should drink Brawndo : It's got electrolytes
Old 20th July 2012, 10:09 PM   #1642
I've ordered the same Hifi 2000 enclosures that nAR uses (for both the Pearl 2 and the power supply). They look beautiful.
Old 23rd July 2012, 09:52 PM   #1643
Hello,
It's been a while since i've been to the board and Im back and wanting to build a Pearl II phono. I just don't know where to start. Last time I left it at the power supply look up. Since there wasn't a simple configuration I wasn't able to get past that part.
Any help welcomed.
Old 1st August 2012, 06:02 AM   #1644
Have anyone built this all in one box, internal layout similar to the Pass Labs XP-15 phono? I prefer a 1 box solution.
Old 1st August 2012, 03:41 PM   #1645
6L6 is online now 6L6  United States
6L6's Avatar
It is possible, but you must have some internal shield or can for the transformer.
If I place my RIAA chassis on top of the PSU chassis, it will hum. Once there is about 12-18 inches between the 2 chassis, it's silent.
Perhaps you might want to get a very small box for the transformer, and put the rest in the big box?
Old 1st August 2012, 03:47 PM   #1646
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
I would go with a two box solution, maybe put the tranny and diodes in it, and connect it with the PowerCon connectors.
Old 1st August 2012, 05:59 PM   #1647
nar is offline nar
nar's Avatar
I really second those 2 ideas. Whilst running former in another housing may seem troublesome, extra work, extra umbilical and connectors, but I can say by experience it's really worth it. Nothing worse than having extra hum whilst using a low cart output, that you chose for delicateness' of sound !!!!
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 2nd August 2012, 06:20 AM   #1648
Thanks guys. I know its a significant benefit to have a separate PSU since this is a DIY project building from scratch, whereas people have to accept the commercial 1 box version as built. Seeing a picture of the internals of XP15 tells me its alright to copy the same layout, morover the tranny doesn't look shielded. I intend to shield it. Afterall countless pre amps manufactured are 1 box. I've planned to have a pair of Cinemag SUT at the input. Its also intended for MC mode only. Thats why I'm still looking to reduce the gain to 40db maximum.
I'm going to give it a try to mount the PSU the same way as XP15 and see if any issues crop up. If I can get away from 2 box, I'll be a happy camper.
Pic taken from the internet.
Old 2nd August 2012, 11:47 PM   #1649
AVWERK is offline AVWERK  United States
AVWERK's Avatar
Or you could try a 3 box solution.
David.
Old 3rd August 2012, 12:00 AM   #1650
wayne is offline wayne  United States
In the hills
A single box may work depending on the transformer. The XP15 transformer is shielded and actually is now double shielded and uses a low noise design. I tried an off the shelf unit and noise was 20 dB higher. They are also rotated for best noise on the original Ono they we're at 90 degrees.
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright ©1999-2017 diyAudio
