Pearl Two - Page 162 - diyAudio
Old 11th July 2012, 08:27 AM   #1611
nar is offline nar
nar's Avatar
Originally Posted by Siberia View Post
Not sure if major, though. I can only guess, I would be better off with upgrading TT and cartridge. Planar 3 has a lousy coupling between motor and plinth. I would love to dismount the motor off the plinth onto some solid base and add a Geddon PSU to it. A cartridge change would benefit too. My current one was bought used on ebay. Some german gentleman sworn he used it less than 100h correctly mounted. As it was my first cartridge, I can't really judge.
You're right about Rega setup. It's good but you can find even better. The major upgrade to Regas is to change the cart for something better. Your cart seems fine, but mind the VTA of the RB 300 might need to be re-adjusted. Rega carts are not very high and higher cartridges need the arm to be set up "higher" on the plinth to have the right cutting angle intended. Extra accessory is needed.
More even careful you must be installing the cart on the arm finding for the "right" position. Please do use Vacuum State free protractor. It can take 2 hours mounting !!! and weeks of patient fine tuning to be well set.
Back to PEARL II, I'm thinking weather some more precise R matching, different caps or getting closer voltage values to Wayne's would benefit? In other words, is there's anything left to tune? Or perhaps it's too silly, as my current rig wouldn't be able to carry out the differences.
Let us hear Wayne about that
Best,
AnaŽl
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 11th July 2012, 09:06 AM   #1612
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Originally Posted by nar View Post
Second is Pearl II with Salas Shunt Reg PSU
That goes without saying! I'm not building anything without it hehe
VTA spacers are there to be tested. But then again, every record is different and you can't adjust every time accordingly. I've tried Guru protractor, which I couldn't get right. Maybe it really takes too much patience?
Joining you for waiting Wayne to chime in.
Old 11th July 2012, 09:47 AM   #1613
Hi all,
I presume the total gain for the given circuitry is 55db. What do I need to change to reduce the gain to 40db total gain. This is because I intend to use permanently install a MC SUT which will have about 30db gain. About 70db is ideal for my requirement.
Old 11th July 2012, 10:04 AM   #1614
Salas is online now Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
I think that the wav files that end with 2 are easily more dynamic and defined.
Old 11th July 2012, 10:58 AM   #1615
Siberia's Avatar
Thanks for listening, Salas. Stage 1 will go for sale which will hopefuly fund my new cartridge.
Old 11th July 2012, 12:56 PM   #1616
nar is offline nar
nar's Avatar
Youpeeee
My bro has P3, mounted a Denon DL 110 on it in replacement of the old Elys cart. It took 2 hours to find roughly the guru points. But once break in is done, what a difference !
Best,
nAr
Old 11th July 2012, 03:00 PM   #1617
Siberia's Avatar
Originally Posted by coolmaster View Post
Hi all,
You need to lower R16. To what exact value, it remains a mystery to me and, again, maybe Wayne could help us here. I was aiming for 40 dB too and installed 47K instead of 100K. This resulted in a bit more than 42.5 dB, which I can tell by comparing to my previous stage.
Old 11th July 2012, 04:25 PM   #1618
nar is offline nar
nar's Avatar
Gain figure of 1st stage is roughly 35dB gain
Losses in passive RIAA about 20 dB
2nd Stage gain as per schematic is (R16+R14)/R14 as non inverting opamp
Per schematic x 101 times so, about 40 dB
Total Pearl gain by default 55 dB
To get 40 dB total gain for Pearl II you need to reduce 2nd stage gain to 25 dB or so (= increase feedback !!!)
R16 can be lowered, but you change Cx adjustment too I guess
Passing R16 to 20k gives you : (20+1)/1 = 21 times or 20 log21 = 26,4 dB
Another option is to change R14 value, with a 5k you get
(100K+5K)/5K = 21 times or 20 log21 = 26,4 dB
Ball park maybe
Best,
nAr
Old 11th July 2012, 04:38 PM   #1619
ra7 is offline ra7  United States
I think nar deserves some kind of award here... for helping out so many people in this thread! Good work!
Old 11th July 2012, 04:41 PM   #1620
nar is offline nar
nar's Avatar
It is always subject to caution ... and verify by your own experience ... I can make mistakes, epecially whilst doing 3 things at the same time
nAr
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright ©1999-2017 diyAudio
