Pearl Two - Page 157 - diyAudio
Old 5th July 2012, 01:43 PM   #1561
nar is offline nar
nar's Avatar
Oh, problem with those. Should be around 8 - 10 V
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 5th July 2012, 01:52 PM   #1562
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Does that mean replacing?
Old 5th July 2012, 01:52 PM   #1563
nar is offline nar
nar's Avatar
Are you sure value of R5
nAr
Old 5th July 2012, 02:03 PM   #1564
Siberia's Avatar
Took them out and both say 1.498 k. But then there's R7. I've read here about trouble installing it. I've experienced them too, but ended up soldering it. Seems OK.
EDIT / I have two spares for ZVX450.
Old 5th July 2012, 03:14 PM   #1565
nar is offline nar
nar's Avatar
For sure the sub mc regulator has a problem. And the cascode too. It seems a soldering issue to me, check again all solders. Do you have proper R28 & R29 idle values ? those should measure about 1V
Best,
nAr
Old 5th July 2012, 03:33 PM   #1566
Siberia's Avatar
I was just desoldering Q3, when I fipped and made a picture of the underside, focusing on the section that can cause trouble:
http://i49.tinypic.com/2e5uo2x.jpg
Nevermind those dirty holes in the middle I'll wipe them clean.
Old 5th July 2012, 04:04 PM   #1567
Siberia's Avatar
Across R28, R29 I read 1.1V. Changing Q3 didn't help. What's the practice, if the solder looks OK, but there surely must be trouble somewhere? Desoldering, soldering action on cascode section?
Old 5th July 2012, 04:13 PM   #1568
ra7 is offline ra7  United States
Have you got the jumper in place of R15 or a resistor?
Old 5th July 2012, 04:20 PM   #1569
Siberia's Avatar
rahul, I've got jumpers there.
Old 5th July 2012, 04:45 PM   #1570
nar is offline nar
nar's Avatar
I see a solder plot at the right bottom of the pic, seems to make short between gates and ground plane
otherwise solders look OK.
nAr
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
