#1321 |
Rich
I would guess the problem is with the solder joints... again. You could fix this board - or start anew. Make sure you test your components because others beside R29 might be gone now... |
#1322 | |
![]() I would get a new soldering tip, and remove all - resolder all new. With shiny / well done joints. For a simple resistor/pad joint, heat with screw driver type tip, at 45° angle so it touches both component lead and pad. Heat for about 3 seconds or so, by tight contact. Pressure must be enough to transport the heat. So, holding the pcb in a vice is a good idea for this Then, apply flux. It must go all over and flow, don't add too much at the same time; better joints are done with minimal quantity flux. Otherwise it takes more time to cool up, will overlap with ground plane adding complications later. When flux as "wetten" all wanted, quickly remove the soldering tip. It must consolidate in about a second. You should see the process with your very eyes ! Optional : After each soldering, verify there is no short between pad and adjacent ground plane/pad. Best, nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
#1323 |
thanks guys.
I'll remove everything from the output and test the input again . I need to order new tips and a couple of parts. Obviously , I would like to keep the board if the input is still good , if not , I'll order a new board . nAr , if you could spare a couple of ZVP 3310 that would be great ? . I can't find them in the UK . Thanks for your help ,Wishing you all a wonderful holiday , Rich |
#1324 |
nAr - Very good advice.
Rich - Board should still be good. There is enough copper on this one for the traces not to lift. Best wishes to all for the Holiday season! Pierre |
#1325 | |
Oddly, whether grounding the Mitsu to the star, or leaving it un-grounded, makes absolutely no difference in the noise level. Holding the end of the ground wire between my fingers reduces the noise quite a bit. This is strange, I never owned a table that behaved this way. Update 2: This was happening with a Pickering XSV-3000 cartridge. Using a Grace F-9 cart, there is tremendous hum with the table left un-grounded. The one difference between the carts is that the Pickering uses a grounding strap between one of the pins and the metal cart body. Update 3: Problem solved. Since the Pearl 2 reverses phase, I reversed the polarity of the cartridge leads to compensate. Apparently this causes grounding problems, since putting the leads back to the proper polarity eliminated the buzz. Last edited by McQuaide; 24th December 2011 at 03:01 PM. |
#1326 |
..... Input stage is un-damaged
I have removed everything from the output ... I'll clean it good with solder braid and replace everything .
#1327 |
Grounding issues can be tough to troubleshoot, because the noise tends to come and go, is different with different turntables, and can change depending on the location of equipment and cabling, what's being touched, etc. I kept making changes based on the advice of various individuals, thinking they worked, only to find that the buzzing sound came back with a vengeance.
Well, I finally have a completely quiet Pearl 2, based on 6L6's advice. My config is what he recommended:
So a hearty thanks to 6L6, this had been bugging me for some time! Mark |
#1328 |
Mark,
Where is the pcb star ground? Is it the pad between C6 & C4, above C12? |
#1329 |
Yes, the unmarked hole between C4 and C12. Connecting these and the TT ground to the chassis killed the noise completely.
Someone also said to ensure the jacks are isolated from the chassis, which mine are. |
#1330 |
Thanks.
| Another diy-pearl... | lykkedk | Pass Labs | 18 | 15th June 2007 04:44 PM |
| ono or pearl PCB's | mantisory | Pass Labs | 1 | 28th September 2006 11:12 PM |
| Pearl need help | dzkh63 | Pass Labs | 1 | 26th September 2006 03:16 PM |
| WTB: Pearl PCB | aire | Pass Labs | 1 | 26th February 2006 10:51 AM |
