Pearl Two - Page 129 - diyAudio
Old 20th December 2011, 12:55 AM   #1281
PierreQuiRoule's Avatar
Rich - The circuit behaves like the potentiometer is the wrong value. Please would you verify that it is a 5 kohm potentiometer you put in. It might be worthwhile removing and testing it. Do you have a spare one ?
We want 0 v at the P1 test point...
Pierre
Old 20th December 2011, 01:24 AM   #1282
richluvsound's Avatar
Thanks Pierre ,
will do . I did and it checks out perfect ...Clicks at 5.18K
Rich
Old 20th December 2011, 02:47 AM   #1283
Originally Posted by exojam View Post
found the answer in post 555. Sorry.
James
James - Yes, these NJR parts are the ones that Wayne listed in the article. I remember them having a lower noise specification than those made by other manufacturers. My Pearl 2 is very quiet with them.
Pierre
Old 20th December 2011, 02:56 AM   #1284
Originally Posted by richluvsound View Post
Thanks Pierre ,
Rich
Oh well... sorry about the trouble. Perhaps some pictures might give us a clue?
You are sure you cannot adjust the P1 test point to zero with the potentiometer?
The lowest that pad will go is 10 volts? Are you sure it is not -10 volts? It is a very sensitive adjustment. Quite easy to miss the 0 volt and overshoot into the negatives... Note that +/- 0.1 V would be close enough.
Pierre
Old 20th December 2011, 04:34 PM   #1285
Trying to get the V to stay in the mV ....
Old 20th December 2011, 06:58 PM   #1286
Zen Mod is online now Zen Mod  Serbia
Zen Mod's Avatar
good picture ..... but problem is that all solder joints looks older than I saw on some tube amps from yore time
in this moment I'm doubting that you didn't scorched even some passive part , besides active ones ........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 20th December 2011, 07:44 PM   #1287
nar is offline nar
nar's Avatar
I hate to say it, but it is also the way the pic looks unfortunately.
There's either a problem with soldering technique, flux and/or soldering station usage. Sometimes older stations iron endpoints do not work well with unleaded. Sometimes temp is set too high, unadequate to the flux used and it can nick some active and even passive parts. Are you sure you do clean the iron end with a wet sponge or metallic equivalent between each solder point ? The endpoint should be perfectly clean and shiny between each solder point with no residue, black or even gold one. When I power up station, once temp is reached I always "clean" the endpoint by adding some fresh flux, and letting it burn for seconds before cleaning the endpoint perfectly with the wet sponge. Then my solder session can begin.
Could you post us pics of an other amp you made ? Do the joints also look like in the pic you just sent ?
Again, I hate to say. But some errors couldn't be corrected if the work is faulty.
Best regards,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 20th December 2011, 08:17 PM   #1288
The amp I made is on loan at the moment .... I use a wetting compound and clean the tip often . I use 380 C for most parts and 450 C for the ground plane parts .
I think I should strip the output stage and check all parts for failure . Use new parts where needed ....
I was told that I wasn't using enough heat , now I'm using too much LOL
I guess it must be rocket science after all .
Perhaps someone could recommend some products ... I have mentioned the products I use for your opinions in this thread.
Merry Christmas all
Rich
Old 20th December 2011, 08:26 PM   #1289
nar is offline nar
nar's Avatar
Merry Christmas all
Rich
Rich
Please try accordingly to your flux. For using my Cardas tri eutectic for 1st time I tested from 150C by increments. I then settled on 330C which is plain high. Instead of pushing the temp for ground planes connections, you'd better stay on the same temp & change the endpoint to take a bigger one, flat screwdriver model instead of ballpoint small, that fits small dense areas and tiny resistors.
I'm only willing to help.
Happy Christmas to everyone here, peace and joy in the world
Warm regards.
nAr
Old 20th December 2011, 08:54 PM   #1290
Cheers nAr,
I bought my soldering station second hand ... Its been serviced ,but the points are not brand new .... perhaps Santa will be kind I use 1.5mm chisel
point that has seen better days ...
Rich
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
