Pearl Two - Page 126 - diyAudio
Old 17th December 2011, 09:58 PM   #1251
6L6 is offline 6L6  United States
6L6's Avatar
Originally Posted by McQuaide View Post
I'm using a star ground scheme recommended here. The Pearl 2 circuit grounds, output jack grounds, power supply circuit ground, and turntable ground all come together to a central star point. Earth is connected to the star through a 10 ohm resistor. Earth is also connected to the Pearl and PS chassis.
What has worked in my Pearl and Pearl 2 is this -
Safety Earth - only connected to the primary side of the PSU and PSU chassis.
V+, V-, Vgnd floating in both chassis.
Input and output RCA jacks floating.
Ground lug connect to chassis.
PCB starground, (a lonely, unlabeled hole under C4 and above C12) connect to ground lug.
Old 17th December 2011, 10:15 PM   #1252
Itsmee is offline Itsmee  England
Itsmee's Avatar
Just re-read your post, try connecting the turntable ground to the Pearl chassis instead.
6L6 beat me to it.
Old 17th December 2011, 10:16 PM   #1253
PierreQuiRoule's Avatar
Originally Posted by richluvsound View Post
what should be my next step ? Would you advise using 2.2k resistor @ Q2 and installing other parts first ... ?
Rich - Yes, it would be a good idea to test the bias throughout the second stage before running a signal through it. Solder a 2.2k in lieu of Q2. Leave the gate (middle pad) of Q2 unconnected. Solder all components. Double check all the joints... Fire one channel up. Measure voltage on both sides of R28 and R29. Wayne posted what these should be. If all is good, then see if at R10 you get in the ball park of +2 volts (my guess for running with a temporary 2.2k.) If you get no crazy readings for one channel, then repeat for the other.
sorry about all the questions Sir
I find this fun and am happy to help .
Pierre
Old 17th December 2011, 10:23 PM   #1254
richluvsound's Avatar
Just checking my ZTX 450 ..... meter on ohms , neg to C then Pos to B and then check neg to E and pos to B .... is this correct ? what figure should I be looking for ?
Old 17th December 2011, 10:29 PM   #1255
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
useful link :
Basic Car Audio Electronics
just look at this ..... http://www.bcae1.com/ampfail.htm
then all other pages
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 17th December 2011, 10:58 PM   #1256
thanks Zen .... very useful
Old 17th December 2011, 11:37 PM   #1257
Pierre
I'm in the ball park ... for the voltages on the schematic - with a bit of oscillation . I'm .9 VDC @ `+ output . Showing 7.56 VDC @ R10 ... which is the same as Q6 C ... BTW ,should output be shorted for this ?
Opinions please !
Old 17th December 2011, 11:53 PM   #1258
Zen Mod's Avatar
input yes , but output not
Old 18th December 2011, 03:11 AM   #1259
Rich - Ignore the + output. The one that matters now is R10.
Can you bring the voltage on R10 closer to 0 V by adjusting P1 ?
Pierre
Old 18th December 2011, 10:58 AM   #1260
Pierre
I have 0 @ the bottom of R10
Out put
R27=-22.53
R6 = 17.50 OSC
R13 = 2.0 OSC
R28 = -23.14
R31 =-24.48
R29= -23.15
P1 = - 5 OSC
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
