Pearl Two - Page 118 - diyAudio
Old 13th December 2011, 04:53 PM   #1171
richluvsound's Avatar
Originally Posted by nar View Post
have you tried R9 mod as Pierre said ? which V on jfet drains now ?
Best,
nAr
Hi nAr,
no I have not tried that ... I think I need to concede defeat here and ask for direct intervention . 6 and I must have spent 15 hours over the past 2 weeks trying to get this thing to work .
I really need to ask if there is anyone that would be good enough to take a look at these boards for me . I don't have a ton of cash ,but I would be willing to pay someone something for the help .
I can't get the P1 even close to zero . I get nothing ,but a static sound when I test it with a signal .
I don't have scope . I just have too much money in this project to walk away . I don't like quitting ,but I do know I'm out of my depth with this .
F^*&^*^)*( IT . I'm sick of looking at it !
Rich
Old 13th December 2011, 05:53 PM   #1172
I would be more than willing to build an enclosure in exchange for time !
Old 13th December 2011, 06:16 PM   #1173
nar is offline nar
nar's Avatar
Originally Posted by richluvsound View Post
Hi nAr,
Rich
Rich
you have to be patient, getting 1st stage working properly without 2nd stage.
In case, remove all active devices of 2nd stage or biasing resistors for 2nd stage
from v+ v- to work on 1st stage alone.
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 13th December 2011, 06:30 PM   #1174
Hi nAr, merci !
remove P1 , Q5,Q2, Q10,Q11,Q4 ?
Rich
Old 13th December 2011, 07:22 PM   #1175
wayne is offline wayne  United States
In the hills
If you want to adjust bias on Q3 it is best to adjust R10. R3 is part of the equalization network. I may have suggested the wrong resistor.
power supply voltage can also be dropped with some 5W zeners as part of the CRC filter network. Ten Ohms caps 100 Ohms 39 volt Zener. a little fiddling and this should get you a shunt regulator feeding the 24 regs.
Old 13th December 2011, 07:37 PM   #1176
nar is offline nar
nar's Avatar
Hi nAr, merci !
Rich
Yes. And see how 1t stage goes by Pierre suggestion ... 4 fets with 9-10V @drain = target
Best,
nAr
Old 13th December 2011, 10:06 PM   #1177
PierreQuiRoule's Avatar
Just Q10 and Q11 will do.
Old 13th December 2011, 10:32 PM   #1178
Ok, I have P1 and the led in the output stage and just 1 fet ( at the moment in the input )... i'll check the voltages then put the other 3 back in and post the voltage in the morning .
Rich
Old 14th December 2011, 12:19 AM   #1179
Oh... You mean that the resistor at the collector of Q3 (R9, 499 ohms) plays in the RIAA filter? We don't want to mess with it then!
Got it, I should have lowered the voltage at the base of Q3 through the resistor between its base and ground (R10, 10k).
Am I ever glad I asked
Old 14th December 2011, 12:25 AM   #1180
Done. I put R9 back to 499 ohms, and lowered R10 from 10k to 3.22k. This biases Q3 at Vc=5.1 > Vb=4.4 > Ve=3.7.
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright 1999-2017 diyAudio
