Pearl Two
Pearl Two
Old 24th December 2010, 07:15 PM   #591
budwiser is offline budwiser  United States
Thanks nar for the artwork.
Old 24th December 2010, 08:47 PM   #592
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Pearl Two
Just use first rate MilMax IC socket, gold plated, high insertion force. TO-92 fits perfectly in these. I used them years ago in my PassLabs Xono and never had a problem. I used them now with all matched parts. On my Pear 1 I had a burned FET from one of the QUAD (certainly from a very bad spark I heard with a defective tonearm wire on my Thorens TD124. It was then easy to find a match from my stock of FET. In circuit matching is also the best.
I bought 0.1% 10 ohms resistors for the matched Quad.
Old 25th December 2010, 08:55 AM   #593
nar is offline nar
nar's Avatar
As I thought
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 25th December 2010, 08:56 AM   #594
nar is offline nar
nar's Avatar
You're welcome
Old 29th December 2010, 08:00 PM   #595
audiorasp is offline audiorasp
Pearl Two
Default Film caps
Can anyone recommend a source for the .01uf, .1uf, .033uf film caps as listed in the parts list for the Pearl 2 ? The suppliers that I know of all show no stock, with lead times of many weeks.
Thanks,
George
Old 29th December 2010, 09:09 PM   #596
nar is offline nar
nar's Avatar
Thanks,
George
Wayne used some Wimas MKP and maybe he can lead to some good source, but did you try Mouser, Digikey or Newark ?
Best regards,
nAr
Old 29th December 2010, 09:38 PM   #597
Pearl Two
Hi nar, Thanks for the reply.
I've searched Mouser, Digikey, Allied, Newark & RS Components with no luck.
Maybe I'll look into adapting some of the surface mount 2% film caps that are available.
George
Old 29th December 2010, 09:49 PM   #598
studeb is offline studeb  United States
studeb's Avatar
you could try TAW down in Burbank
Capacitors, Resistors, Connectors, LED, Varistors from WIMA, AOP, PIHER, NEMCO, FISHER, CAPAX, ARCO, SAURO, SFI
mouser has FKP 0.01 in 5% and 1%, they have 511 of the FKP 0.033 in stock, and they have 594-2222-417-41004 with 10mm lead spacing
Old 29th December 2010, 10:42 PM   #599
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Pearl Two
I used all MKP1837 from parts connextion, but it looks like the .1 are out. They don't fit in well, but can fit if you work with the leads a bit.
Using a plain Denon 103 cartridge, the phono rig with my Pearl 2 sounds totally nonagressive, sweet and detailed, with a good soundstage. Some of this the nature of the cartridge character for sure.
I used a Salas shunt Reg for the power supply. (attached)
In order to achieve good gain, decreasing R14 did not add much gain, but replacing R15 jumper with a 1k resistor did give more gain. It could still use a bit more.
Salas Boards GB 2017#1 SHIPPED | GB 2017 #2 Click Here to Sign Up! | Hot-Rod DCB1 boards and kits In Stock, PM | M2C Boards In Stock
Old 30th December 2010, 11:43 PM   #600
ra7 is offline ra7  United States
Pearl Two
Algar Emi, thanks for that wonderful parts list. For those of you looking for parts, I'm getting almost everything from mouser. It's all there, just have to look hard enough.
Algar, the transformer is a 2x22VAC... 30 V is after rectification and filtering. You have it down as 30VAC in the parts list.
One question: For LM7824, will this work as a replacement?
MC7824ACTG ON Semiconductor Linear Regulators - Standard
Here's the part number if the link doesnt work: 863-MC7824ACTG
Mouser is out of LM7824 for now.
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright ©1999-2017 diyAudio
