Pearl Two
Pearl Two
Old 27th June 2018, 12:06 AM   #2901
Eric is online now Eric  United States
Eric's Avatar
Pearl Two
Depending on output level of the cartridge you are using, you may need to degenerate the jFets in the first gain stage as well. My AudioTechnica 150MLX has 5.0mV output and even after fiddling with R14/R16, it was still overloading and distorting on some LPs. Increasing R21-R24 from 10R to ~22R reduced the gain of the first stage and removed the overload I was getting. I just lifted one leg of the original resistors and added another resistor to the empty hole and connected them in series. A quick jumper will return things back to the original state.
My DIY Basement Theater, Aleph-X Amps, Avro Open Baffle Speakers, LDR based DCB1 + BA-3 pre, Pearl II, highly modded Technics SL-1200, F4, a40, several ACAs, FHXL, Tang Band 1772 bass-reflex
Old 27th June 2018, 04:02 PM   #2902
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Pearl Two
Reducing the first gain By increasing resistor values impairs noise performance. Bedides, the problem is in the second gain stage.
Old 27th June 2018, 04:31 PM   #2903
Eric's Avatar
Pearl Two
This is interesting to know, Jack. With a 5mV output MM cartridge, I was unable to avoid overload distortion through adjustments to the second gain stage alone. Perhaps I need to experiment further. Of course, the other solution is to get a moving coil cartridge as was intended
Old 7th July 2018, 04:48 PM   #2904
jackinnj's Avatar
Pearl Two
If you’re clever you can skip the passive RIAA and incorporate it in the second stage feedback loop.
Old 8th July 2018, 02:21 AM   #2905
Eric's Avatar
Pearl Two
Sadly, I need to learn more before I consider myself to be clever...
Old 8th July 2018, 11:48 PM   #2906
edwyun is offline edwyun  United States
Am I correct to assume that using a LPS will be better than a SMPS/wall wart?
Old 8th July 2018, 11:57 PM   #2907
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
Perhaps...?
One thing is sure, a bipolar SMPS of the proper voltage will be a challenge to find.
Old 12th July 2018, 02:24 AM   #2908
Perhaps I should stop searching for one then. LOL.
Old 13th July 2018, 09:38 PM   #2909
jackinnj's Avatar
Pearl Two
Perhaps...?
DK shows 52 (dual) +/-24V SMPS in stock.
Unfortunately, you'll need a bit more than that if you plan to use the LMxxx regulators on Wayne's boards.
Old 13th July 2018, 10:05 PM   #2910
6L6's Avatar
Pearl Two
Yup. That's the issue.
I'd love to try a switcher feeding this, the newer ones really are getting quite good.
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
