Pearl Two
Pearl Two
Old 9th August 2013, 03:07 PM   #2251
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
Jim - Yes, it will live up to your expectations... It's that good.
Old 9th August 2013, 06:46 PM   #2252
Jim50hertz is offline Jim50hertz  United Kingdom
Thanks for your reply 6L6, very good to hear. I must say I've been through your build report a good number of times and found it very inspiring and helpful and, having read through the entire thread here I'm awed by the level of knowledge and expertise, and by the sheer generosity.
Can't wait to get started! And more so to get finished and hear that vinyl in a better light
Old 7th September 2013, 08:52 AM   #2253
JOHNNYCR100 is offline JOHNNYCR100  Abu Dhabi
Default Pearl 2 PCB Dimesnions
Sirs,
Can anyone give me the exact dimesnions of the pearl 2 PCB Boards please?
thanks awfully
Johnny
Old 7th September 2013, 09:42 AM   #2254
The boards are 7" by 5".
Parts are ordered. Boxes will be ordered today.
Old 7th September 2013, 12:13 PM   #2255
McQuaide is offline McQuaide  United States
Which boxes are you ordering?
Old 7th September 2013, 12:26 PM   #2256
Modushop model 1NGXA383 for the RIAA boards, possibly a smaller box for the PSU but I may eventually build a second PS and go dual mono so may opt for the larger case here too.
Old 7th September 2013, 09:08 PM   #2257
c_door is offline c_door  Italy
My Pearl2 is in a Modushop box 1NSL02230B modushop.biz
Pictures on post #2218 in this thread.
Old 8th September 2013, 02:50 AM   #2258
Default Main PCB positioning
Thanks for the info Jim, good to know.
Is it possible to position the main (gain stage) PCB on top of each other with stand offs, then put the PSU in the far side of the box at the opposite end with some shielding/distance-, that way using 1 box and saving a bit of money- or is it false economy?
cheers Johnny
Old 8th September 2013, 02:55 AM   #2259
6L6's Avatar
Pearl Two
Honestly the Pearl isn't truly quiet until the transformer is 3 feet (1M) away from the RIAA boards.
Make the PSU box ugly, so you are not tempted to show it off, and want to hide it far away from the system. That way it is a long distance from the RIAA.
Old 8th September 2013, 06:16 AM   #2260
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Pearl Two
That happens with all very low input signal and high gain devices. AC fields must be kept well away. Even if the main unit box is made by thick ferromagnetic material and the general grounding is done in the best way, the external signal cables are still susceptible.
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
