Pearl Two
Pearl Two
Old 5th April 2013, 06:52 AM   #2121
FormosaWest is offline FormosaWest  Canada
Thanks! I think this might work.
Old 5th April 2013, 07:09 AM   #2122
Originally Posted by PKI View Post
Has the pass store just doubled the price on the boards? :-(
Nope. I just talked with them. Its 200 for 2 boards and 2 x 6 matched JFETS.
Confusing though eh.. I thought the same.
Old 5th April 2013, 07:40 AM   #2123
Phase Inversion Switch
found that looking for means to invert phase... not sure if its quite right. would be interested in critical opinions of others. I suspect (without knowing) that impedance issues might arise?
i might forget it all together and, as advised previously, deal with it down the road if i can. Thought id share the info incase others find themselves pondering the same ideas
Old 5th April 2013, 04:39 PM   #2124
jhsjhs99 is offline jhsjhs99
Hi folks,
I have what is probably a dumb question, most appropriate for budwiser, as it is his picture, but I am guessing many can answer it. The link is to a picture of budwiser's power supply, which I am trying to copy. This is my introduction to electronics projects.
http://www.diyaudio.com/forums/attac...9-22.59.04.jpg
My question: in Wayne's schematic, he runs the hot line from the wall into the fuse, than to the transformer. It looks like in this photo the neutral is running to the fuse. I assume I am missing something obvious, but would appreciate it if someone would tell me what. I am a trial and error kind of guy, but not when it involves 120 volts. Thanks!
Old 5th April 2013, 04:48 PM   #2125
Marra is offline Marra  United Kingdom
Pearl Two
I think if you look closely the hot wire goes from IEC connector to a switch and then from the switch to the fuse holder and on to the transformers.
It might be a good idea to build a bulb tester; saves a lot of blown fuses etc.
Old 5th April 2013, 04:51 PM   #2126
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
Yes, the hot comes out of the IEC plug, into a switch, thence to the fuse.
Always fuse the hot.
Old 5th April 2013, 05:22 PM   #2127
Got it, thanks. I misread my plug.
Old 8th April 2013, 09:32 PM   #2128
AuroraB is online now AuroraB  Norway
AuroraB's Avatar
Since the BL version is more or less unobtanium these days, have anybody built the v.2 with GR types? Operating points could be adapted, but is there any loss of gain??
While the Lie leapt from Bagdad to Constantinopel, the Truth was still looking for it's sandals!
Old 8th April 2013, 10:57 PM   #2129
McQuaide is offline McQuaide  United States
My power entry module has both hot and neutral fused for some reason.
Old 9th April 2013, 02:22 AM   #2130
budwiser is offline budwiser  United States
Here are a few extra pictures that go with the one jhsjhs99 was talking about.
Pete
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright ©1999-2017 diyAudio
