Pearl Two
Pearl Two
Old 4th April 2013, 03:35 PM   #2111
McQuaide is offline McQuaide  United States
Since the Pearl 2 is my only phono preamp I reversed all of my cartridge leads. If someone was using multiple preamps I can see how this could be annoying.
Personally I can't hear the difference, but some people say they can.
Old 4th April 2013, 04:15 PM   #2112
bnorrish is offline bnorrish  United States
bnorrish's Avatar
I did an comparison switching speaker polarity listiening to the first songs of Massive Attack "Protection" (electronic bass tracks) and I could hear it in the bass. Better definition, not as muddy. Far from an exhaustive test but enough for me to keep it reversed and move on.
Old 4th April 2013, 06:18 PM   #2113
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Originally Posted by Cobra2 View Post
And, are you sure that the recordings are phase-correct?
Arne K
Flip a coin on that one.
For that matter, polarity of individual instruments can be random on a multitrack recording.
Old 4th April 2013, 11:45 PM   #2114
FormosaWest is offline FormosaWest  Canada
Totally! swapping cart leads is okay in many cases, such as with my Grace F9 MM except its not always that simple... Heres where i'm coming from.
I listen to headphones 90-95% of the time, and cant just swap driver leads.
Ortofon SPU MC, and the xpression MM. I love em and have owned several other ortofon carts... but there're no wires to swap! So id have to reconsider buying one.. Not that I wouldnt jump on the opportunity to own my own Koetsu in lieu of! mmmmm.. but something about those ortofons.. perhaps its the fond memories.
If I can manage to borrow something such as my uncles Koetsu's im not going to swap leads on it since its not mine. He's meticulously sorted it to use with his Mitch Cotter Setup - B1 TT, phono-stage and preamp. ..and who wouldn't want to listen to their pearl play a koetsu!
..sounds like there arent any novel means to craft an inversion switch into the design since its Single ended... In the end a little phase inversion isnt so bad (as long as i dont think about it)
Ill keep an open mind and if i find anything, i'll be sure to share. ...wonder why wayne did it that way with the pearl2. just a consequence of the design i suppose.
Old 5th April 2013, 12:06 AM   #2115
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pearl Two
there are several ways of swapping phase , but just few when speaking of SE stages ( without going further in debate are balanced phonostages good or not ) ; each of them is having everything with fact - is audio gnd connected to safety gnd , or not
however - gnd is just state of mind
you can ground (connect to safety gnd) cold end or hot end ...... as long you are taking in account what's happening with preceding and following stages
if cart is T4P , you can swap leads under the arm
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th April 2013, 03:59 AM   #2116
PKI is offline PKI  United States
PKI's Avatar
Pearl Two
Has the pass store just doubled the price on the boards? :-(
Old 5th April 2013, 04:17 AM   #2117
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
I don't think so, it's always been $200 for a stereo pair. I think it's just listed differently due to the new website.
Old 5th April 2013, 06:11 AM   #2118
Originally Posted by Wellerman View Post
I got HIFI 2000 enclosures for both the power supply and the Pearl II. Unfortunately I messed up the front panel of the power supply when making the hole for the switch, so I had to re-polish it. It does not look the same anymore, but fortunately it will be spaced apart from the enclosure of the Pearl II.
Some pics:
and the inside:
NICE choice! I ordered cases very similar to those from the very same place! Nice to see how it might look! COOL I like the extruded alum sides. Gives it that top notch industrial POWER look. Going with the neutricon power connectors instead of XLR though, and a P-Core Xformer at 2x24 1A.
Old 5th April 2013, 06:24 AM   #2119
Yes, the balanced debate. Well it would be easier to craft a polarity inversion switch as the two active pins to xlr out could be swapped. (not sure if that would addess the "phase inversion".. cant say i truly understand it all.
But single ended... I dont know if we can just swap Pos and Signal Gnd in the same way.. ..or can we?? I figured that if pos and GND on SE were swapped they'd short and no sound would come out. or maybe i'm confusing signal ground, power ground and chassis gnd..im so new to this though im just guessing. ...
So.. with the RCA.. would swapping Sleeve with Tip do the same as swapping pins in an XLR? Could this be done safely and effectively at the RCA phono input, for example?
Old 5th April 2013, 06:44 AM   #2120
omishra is offline omishra  India
IMO yes if your wires from cartridge to phono input are distinct till phono stage and none of them connected to ground inside tonearm tube or TT. (Somewhere I read, some TT have one of cartridge wire connected to gnd.)
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright ©1999-2017 diyAudio
