Pearl Two Pearl Two - Page 205 - diyAudio
Pearl Two
Pearl Two
Old 8th March 2013, 12:32 PM   #2041
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pearl Two
I'm not playin' guitar ( abandoned learning as teen , having too much other things on mind) , but I repaired numerous guitar amps , re-done more than few guitars - wiring , screening , custom switching arrangements etc.
Magma is French ( not that we didn't had wakoo bands )
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 8th March 2013, 04:51 PM   #2042
bnorrish is offline bnorrish  United States
bnorrish's Avatar
The clip I saw did not sound like French - Kobaian? Typical dumb American view of the world I have.
From Wikipedia:
In a 1977 interview with Vander and long-time Magma vocalist Klaus Blasquiz, Blasquiz said that Kobaļan is a "phonetic language made by elements of the Slavonic and Germanic languages to be able to express some things musically. The language has of course a content, but not word by word."
Old 8th March 2013, 09:45 PM   #2043
Wellerman is offline Wellerman
Originally Posted by Salas View Post
As for the spot on importance question, look at this Toshiba chart. Its the transconductance VS drain current. As you see 5 to 5.6 is practically the same just above the 30 millisiemens mark. So your input stage gain is very close to the original (23mA/4JFETS=5.75mA each on average VS 5mA in original). The larger resistors promote better sharing also. Wayne knew that there is an optimal region at about 5-6mA for the type no matter if adding a bit of nVsqrtHz from the net Rs resistance (Value/4). Its a thermal trade off for each one's dissipation at IDSS and noise most probably. 8.5V or 9.4V VDS at about 0.1V VGS look linear alike. Gate leakage current should be very close too. In a nutshell you should be sorted as you are.
Just to improve my understanding of matters: my quads have around 27-27,5mA. Voltage drop across R21-R24 is within 1mV in a quad (67-68mV, 68-69mV). I have lowered R10 (4k7) to get Vc 6.1 Vb 5.9 and Ve 5.3V around Q3. So there is 5.3V on the drains of Q6-9. Is that in a range where the 2SK170 works less well? What could be the effects on the sound quality? Audible? If the higher mA means higher gain I would actually welcome that (unless of course it degrades sound quality)
Old 8th March 2013, 09:58 PM   #2044
Salas is offline Salas  Greece
diyAudio Chief Moderator
Salas's Avatar
Pearl Two
The curves are steeper there. Bit less linear.
P.S. There was some technical and subjective mix test maybe from a German site that was recommending them at >6.5V but I can't find it now. You better listen on your own with higher source resistors and decide.
Old 8th March 2013, 09:59 PM   #2045
Zen Mod's Avatar
Pearl Two
From Wikipedia:
they're , in fact , World's Citizens , in best meaning of the word
at least to my ( limited ) knowledge , they are having exactly right amount of French wakoosness , and rest is ...... simply put - I adore their music
Old 8th March 2013, 11:06 PM   #2046
bnorrish's Avatar
In general, does operating in the less linear range of a device mean more distortion?
Old 8th March 2013, 11:09 PM   #2047
bnorrish's Avatar
I will need to add some Magma to my collection. I have a fair number of Brit Prog rock (Yes, ELP, King Crimson, Genesis) - quick search and Magma vinyl fetches a premium.
Old 8th March 2013, 11:39 PM   #2048
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
lab page
Old 9th March 2013, 03:38 AM   #2049
Salas's Avatar
Pearl Two
Yes, that was the German link. Thanks Joachim.
Old 9th March 2013, 03:51 PM   #2050
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Rosewood Pearl with hand built case .... still need to put the Power switch in ...
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright ©1999-2017 diyAudio
