Pearl Two
Pearl Two
Old 22nd February 2013, 04:30 PM   #1871
poli is offline poli  Germany
poli's Avatar
Thanks bnorrish and 6L6!
Yes, we had eventually all ZTX450 replaced, so as well the Q10 and Q11.
Old 22nd February 2013, 05:02 PM   #1872
Wellerman is offline Wellerman
Originally Posted by bnorrish View Post
Wellerman - What did you use for the TT ground lug?
a chassis part that is meant for banana plugs, ordered locally. It also accepts bare wire through a hole in the side, but I will attach a banana plug to my TT ground wire later.
Old 22nd February 2013, 05:05 PM   #1873
Originally Posted by poli View Post
Hi everyone,
finally I got my Pass Pearl 2 working!
Poli
That is looking great! The 22 muF caps are quite big, what type are they? Also quite some capacitor real estate in the PSU...
Old 22nd February 2013, 05:08 PM   #1874
Originally Posted by 6L6 View Post
Yes. It's the center of the board's ground potential for the circuit and PSU, and therefore the quiet spot for attaching the phono ground. It's not really mentioned in any of the literature, I know about it only through speaking with Wayne at Burning Amp.
Hopefully the center that I created on my prints (about the same spot) will have the same effect...
Old 22nd February 2013, 05:14 PM   #1875
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
Yes, likely you will have no problem. The original Pearl didn't have the dedicated pad and you needed to make a jumper between a couple components, and that was the ground spot. It worked fine.
Old 22nd February 2013, 05:29 PM   #1876
Replacing the Yamaha HT Receiver, using it as a Pre-Amp out to the F5 made a big difference. Most 'average' listeners would say my current rig sounds great. Compare to a digital source, and it is obvious there is room for improvement on the phono side. 6L6 and others have been polite in saying my Rega Bias 2 cartridge sucks compared to other choices. That may be a future bottleneck after I get the Pearl 2 going.
I also plan on building a B1 buffer pre-amp, it will be interesting to observe the improvements (hopefully) as I upgrade each element. I have Polk TSi300s, OK for the money - another candidate for an upgrade. Thinking a Troels TQWT if I can realistically find the time to build.
Have you lowered the gain for the Bias2 cartridge? I think its output is too high for the standard 55 dB gain (will give you almost 3V ouput). Time to save up for something like a Goldring Eroica
Old 22nd February 2013, 05:34 PM   #1877
Until now I have not heard any hum and that was with the TT ground still connected to the amp in stead of the Pearl. Just a little hiss when I hold my ear to the tweeter.
Old 22nd February 2013, 05:37 PM   #1878
6L6's Avatar
Pearl Two
It's awfully hard to swamp the input of the Pearl. Just run the gain in the stock position. ...don't add any gain, obviously...
If it's quiet, don't mess with it!
Old 22nd February 2013, 06:07 PM   #1879
Yes, but the distortion at 5mV input is already around 0.25% according to the article by Wayne and the Bias2 has even more output. Expect between 0.3% and 0.35% distortion. But you won't destroy it, so just listen and decide if you're happy with it.
Old 22nd February 2013, 06:59 PM   #1880
bnorrish is offline bnorrish  United States
bnorrish's Avatar
I am going to start stock. Dynavector 10x5 is more realistic - down the road a bit. I wish I could change the gear purchases to show up as Home Depot on the credit card so I can hide it from the wife.
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright ©1999-2017 diyAudio
