Pearl Two
Pearl Two
Old 3rd August 2012, 12:12 AM   #1651
Mr. dB is offline Mr. dB  United States
Mr. dB's Avatar
Originally Posted by coolmaster View Post
Thanks guys. I know its a significant benefit to have a separate PSU since this is a DIY project building from scratch, whereas people have to accept the commercial 1 box version as built. Seeing a picture of the internals of XP15 tells me its alright to copy the same layout, morover the tranny doesn't look shielded. I intend to shield it. Afterall countless pre amps manufactured are 1 box. I've planned to have a pair of Cinemag SUT at the input. Its also intended for MC mode only. Thats why I'm still looking to reduce the gain to 40db maximum.
I'm going to give it a try to mount the PSU the same way as XP15 and see if any issues crop up. If I can get away from 2 box, I'll be a happy camper.
Pic taken from the internet.
Since the Pearl Two is already a MC phono preamp, why would you need additional step-up transformers?
Old 3rd August 2012, 02:29 AM   #1652
6L6 is online now 6L6  United States
6L6's Avatar
Pearl Two
Transformers load a MC cartridge in a way that can sound very, very good.
Old 3rd August 2012, 05:54 AM   #1653
coolmaster is offline coolmaster
That's exactly is to be expected.
R28 with 100ohm resistor = MC phono preamp
Without R28 = MM phono preamp
Supposed to be like this, no?
Originally Posted by AVWERK View Post
Or you could try a 3 box solution.
Regards David.
Old 8th September 2012, 11:38 PM   #1654
Mr. dB's Avatar
What are the dimensions of the Pearl II boards?
I'm trying to figure out if the pair will fit a chassis I have. Its internal dimensions are 7 3/4" wide by 11 1/4" deep by 2 1/2" high.
Thanks.
Old 8th September 2012, 11:45 PM   #1655
vdi_nenna is offline vdi_nenna  United States
vdi_nenna's Avatar
Pearl Two Send a message via Yahoo to vdi_nenna
7x5. If you use the intended heat sink for the regulators, it just over 1.5" high.
That doesn't include stand offs.
I build, therefore I am.
Old 9th September 2012, 12:00 AM   #1656
6L6's Avatar
Pearl Two
Yes, that chassis will work, and nicely!
The PSU won't fit, but that can be built in a much smaller (and uglier, as it can be hidden...) case.
As mentioned, do pay attention to the height of your heatsinks and big caps. But it shouldn't present a problem.
It's a fantastic phono stage. Of my DIY phonostages, only the original Pearl is anywhere close to as good.
Old 9th September 2012, 12:07 AM   #1657
vdi_nenna's Avatar
The PCBs alone are amazing. Now I understand the cost.
Btw- can silver mica caps be used on the output MOSFET? I have 4 in that size and they measure exactly.
10pF fr freq compensation.
Old 9th September 2012, 01:13 AM   #1658
6L6's Avatar
Pearl Two
Yes, silver mica is fine.
Old 9th September 2012, 04:26 AM   #1659
Mr. dB's Avatar
Thanks to both of you!
I've got three of those cases, so I was hoping to fit the phono in one, line stage in another, and the third would house raw DC supplies for both. The cases look exactly like this, except without any knobs (yet):
Old 9th September 2012, 04:34 AM   #1660
6L6's Avatar
Pearl Two
Ooh! Silver bumper Naim gear. Nice!
Are your cases reproductions or just something very similar?
Use 2 for the Pearl, PSU in one, both RIAA in the other.
Save the third for a linestage/selector.
Or, if you want to pursue another direction, sell the cases to me...
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
