Pearl Two
Pearl Two
Old 8th July 2012, 07:49 PM   #1601
PierreQuiRoule is online now PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Pearl Two
Originally Posted by Siberia View Post
So here we are. Q3:
Vc 7; 6.9
Vb 5.4; 5.4
Ve 4.7; 4.8
These are perfect. You're rolling. Now go and listen again.
Pierre
Old 8th July 2012, 07:51 PM   #1602
Pearl Two
You must be joking! There's nothing to regret. We live and learn and I've learned a lot from you.
Originally Posted by nar View Post
Oups, I'm terribly sorry ! I let out the wrong correction accidentally.
Luckily Pierre is here to correct my mistakes
Tomas please report voltages after mods (my repair mistake, sorry, I really apologise) and Pierre's right correction
Best,
nAr
I'm here because I saw your post. Thanks for posting !
Cheers - Pierre
Old 8th July 2012, 08:09 PM   #1603
Siberia is offline Siberia  Lithuania
Siberia's Avatar
Thanks, messieurs. I'll report after a bit of spinning.
Old 9th July 2012, 01:49 PM   #1604
nar is offline nar
nar's Avatar
spin spin spin ...
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 10th July 2012, 09:59 PM   #1605
Siberia's Avatar
Default test
Not being selfish, I thought, I could offer you, guys, a glimpse on the difference (or the lack of it?) between my two phono stages? Here is some excerpts recorded especialy for you. (109MB)
http://wtrns.fr/16Lz7Qc4o_QeGM
I would love to read your opinions. My own is: "it could be better". Duh!
You can also try and guess which is which stage, if possible.
It was recorded swapping stages and polarities on the cartridge, via not yet boxed dcb1 to my old mac which doesn't have a battery anymore, so I had to use noisy PSU. A bit crappy, but still good enough to carry out a judgement?
Old 11th July 2012, 06:50 AM   #1606
nar is offline nar
nar's Avatar
There is indeed a difference between the 2 versions. But most qualities out of the 2 examples are lost in conversion ... you know standard 44,1 isn't up to par with originals.
Plus, it depends which conversion card you use, external maybe ?
For me both records play fine ... TT is the Planar 3 I guess, don't remember which cartridge you have mounted on.
I would perhaps slightly prefer the 2nd versions of the test samples (assuming it is still always same phono stage order), seems to have a more direct and natural sound. I would find also the sense of space a little better. Oh well, I could be wrong after all.
You should build some other shunts to get double mono PSU on Pearl !!! It would be a tiny/but major upgrade I guess
Best,
nAr
Old 11th July 2012, 07:37 AM   #1607
Siberia's Avatar
AnaŽl, that's close to my thoughts. "Tightness" and spatial info is better on the 2nd stage. It has also a bit more gain, it seems. I've tried to level it when recording, though. Turntable is Planar 3 with a RB300 modded arm. My cartridge is Goldring 1012GX.
Double mono PSU of course would be an upgrade. Not sure if major, though. I can only guess, I would be better off with upgrading TT and cartridge. Planar 3 has a lousy coupling between motor and plinth. I would love to dismount the motor off the plinth onto some solid base and add a Geddon PSU to it. A cartridge change would benefit too. My current one was bought used on ebay. Some german gentleman sworn he used it less than 100h correctly mounted. As it was my first cartridge, I can't really judge.
As a second option, I think of ditching Rega and switching to something more decent. But that's a different $$$ story.
Back to PEARL II, I'm thinking weather some more precise R matching, different caps or getting closer voltage values to Wayne's would benefit? In other words, is there's anything left to tune? Or perhaps it's too silly, as my current rig wouldn't be able to carry out the differences.
Old 11th July 2012, 07:54 AM   #1608
nar is offline nar
nar's Avatar
You still didn't tell anyone which was which neither what is the other phono pre
AnaŽl
Old 11th July 2012, 08:06 AM   #1609
Siberia's Avatar
I didn't want to spoil the audiotion yet... First is Graham Slee Revelation, second is Pearl II.
Old 11th July 2012, 08:19 AM   #1610
nar is offline nar
nar's Avatar
Second is Pearl II with Salas Shunt Reg PSU
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
