Pearl Two
Pearl Two
Old 13th February 2012, 08:19 PM   #1371
vinylkid58 is offline vinylkid58  Canada
vinylkid58's Avatar
Originally Posted by AVWERK View Post
Why can,t I drag pics from my desktop to post area... Always a problem for me
You upload them using the dialogue box.
jeff
Old 13th February 2012, 09:46 PM   #1372
AVWERK is offline AVWERK  United States
AVWERK's Avatar
[IMG1421.jpg]
Old 13th February 2012, 09:53 PM   #1373
AVWERK's Avatar
There,s 60k per mono because I can
David
Old 13th February 2012, 10:25 PM   #1374
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
3 chassis? Awesome! I have to know how you grounded it...
Also, are those R-cores? Where did you get them?
Old 13th February 2012, 10:29 PM   #1375
vinylkid58's Avatar
[IMG1421.jpg]
Love the "no nonsense" chassis work.
jeff
Old 13th February 2012, 11:32 PM   #1376
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Pearl Two
[IMG1421.jpg]
They're beauties
Nice analog rig by the way. I would be curious to hear your opinion of the Pearl 2 once you put it to the real test.
What I like about mine: very quiet, lots of gain, huge sound stage, solid bottom, extended top, high resolution, yet non fatiguing. What I am still unsure about: dynamics, and vocals - the latter seem recessed a bit, but this could also be the cartridge (VdH MC One) or its alignment. Overall, I love it.
Old 13th February 2012, 11:58 PM   #1377
AVWERK's Avatar
6l6
The pcb is floating from its enclosure along with the rca,s
The bnc style connector,s outer barrel connects to pcb,s case
I braided the 3 wire power cable (kimber style) floating +\-/sigGD to pcb
Now I put copper braid shielding over the power cable connecting bnc so pcb case is grd.
It terminates inside the PS floating for now (still a work in progress)
The brass ground connection is isolated from its case. This is the signal star ground that connects the pcb,PS ground points, caps etc and the 35amp rectifier mentioned in waynes article
The AC power cord is foil sheilded, but I have not connected it yet. It enters the case on the bottom right into a copper pipe and terminates At the back top to the small pcb that has the fuse,cl60, 4.7 ohm 2 watters, ac cap (xono) style.
The earth wire connects to the PS case. I have not tried a 10ohm/cl60 combo yet here. I haven,t explored the full potential as I need to terminate the power cable shield and foil ac wire to see if any residual noise can get lower. It,s faily quiet now, but I have to put into my regular system. I,m not done yet
David
Old 14th February 2012, 12:10 AM   #1378
AVWERK's Avatar
Oh, the rcores
They were labeled 2x24 at 115v and were actually 2x28 that put me at 40.5 vdc unloaded. I was going to rewire them and still might. I have run right at the limit of the regs at 40, but have backed it down with a small variac for now to 34 vdc.
Still a work in progress
Cant remember who I got these from last winter, but it was an ebay seller and his email sig was john 630 or something. Very expensive when you factor shipping to USA.
David
Old 14th February 2012, 12:22 AM   #1379
AVWERK's Avatar
Pierre
Just listening to what I got so far, it hasn,t grossed me out yet nor produced any fatigue yet. The idea of passing a signal through a 22uf cap didn,t turn me on the whole way, but so far I have to admit those silmac caps seem fairly transparent. Burning it in with fast piano records and of course
Al Demeolia's Elegant gypsy album...if this album doesn,t get your needle cherry red, nothing will!
We,ll see what we get once the dust settles.
David
Old 14th February 2012, 03:51 PM   #1380
budwiser is offline budwiser  United States
Almost done. Just need to do alittle wiring in the main box then on to tuning.
And Audio Dog says, man is it done yet.
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright ©1999-2017 diyAudio
