Pearl Two
Pearl Two
Old 18th December 2011, 02:01 PM   #1261
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Pearl Two
Originally Posted by richluvsound View Post
I have 0 @ the bottom of R10
Excellent news. The right hand side of the stage (Q11 et al) is biased correctly.
R6 = 17.50 OSC
R13 = 2.0 OSC
Gate of Q4 not being close to 0 volt is strange. Can you check the joints of R13? or perhaps Q4 is toast. Re-test it.
What is the voltage -across- R6 ? Between 1 and 2 volts? Can you adjust it to be in that range with P1?
Old 18th December 2011, 02:24 PM   #1262
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Changed Q4 Gate = 4.9 mV OSC
Across R6 = Approx 3.0 V .... No change when adjusting P1
Old 18th December 2011, 03:48 PM   #1263
Pearl Two
Q4 is good now. But your reading across R6 (and ineffectiveness of P1) shows that there is no current through Q5 meaning that both Q4 and Q5 were toast. Replace Q5, and remeasure across R6. Hope you read 1.5 volt. If you do, recheck and note voltages. Replace 2.2k by actual Q2. Compare voltages to those with 2.2k.
Once you have a running board, you will want matched Q4 and Q5. IMO matching is more important for these two than for the quad of jfets in the first stage. This can be taken care of later.
Pierre
Old 18th December 2011, 04:19 PM   #1264
Changed Q5 and still 3.7 across R6 and P1 still flakey !
Old 18th December 2011, 04:56 PM   #1265
Pearl Two
Rich - When you adjust P1, does it change the voltage across R6?
You want the voltage across R6 to be in the order of 1.5 times the voltage across R28. This will indicate that Q4 and Q5 are both drawing enough current.
Old 18th December 2011, 07:19 PM   #1266
approx 1.5 v across R 28
I am suprised by the amount of heat at the 2.2k (Q2 )
Old 18th December 2011, 09:46 PM   #1267
nar is offline nar
nar's Avatar
Seems in the ball park from my remembering, assuming 2,46 mA runs in the diff pair so slightly more than 1mA per se, seems fine
that means 3 mA flowing. Slightly more than the measure on R6 but in an order of magnitude.
But if Vref of the led is 1,65V, you should find about 1V on this resistor ( 1?65 minus 0,65V drop between B and E )
So I suspect your led to have slightly greater Vref than 1,65. Mostly a 2V one can you measure the direct voltage on led ?
Which is the reading on R29 ? That would tell us what current is flowing in here. It should be around 10 mA. Flowing through the 2K2 it means 0,22W. So if you use a 1/4W standard it means near max dissipation, or even on a 0,6W model it can be hot. if you use a Dale 1/10W, it will burn one day or another
In any case you should find very similar measures on both R28 & R29. About a volt.
If you can't get it, you can always keep the led you use actually and change R28 and R29 values. In your case, you could change R 28 for 750R and R 29 for 150R and it would be also fine
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 18th December 2011, 10:02 PM   #1268
Pearl Two
Not quite. R6 feeds Q5 only, so about 1 mA in 1.5 kohm should give about 1.5 volt, as Wayne shows in his schematic. Rich measures twice that.
Old 18th December 2011, 10:09 PM   #1269
Pearl Two
This means the differential pair is biased with 3 mA total. There are 2.5 mA flowing through Q4, leaving .5 mA for Q5. The split should be more even. Again, does the voltage across R6 changes when you adjust P1?
As nAr kindly pointed out, this is normal. It is dissipating about a quarter watt . No worries.
Old 18th December 2011, 10:13 PM   #1270
nar is offline nar
nar's Avatar
Oopps, my bad, should have looked closer. Seems the diff. pair doesn't share the bottom current evenly
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 05:44 PM
ono or pearl PCB's mantisory Pass Labs 1 29th September 2006 12:12 AM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 04:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 11:51 AM
Copyright ©1999-2017 diyAudio
