Pearl Two
Pearl Two
Old 15th December 2011, 03:17 PM   #1201
PierreQuiRoule is offline PierreQuiRoule  Canada
PierreQuiRoule's Avatar
Pearl Two
Rich - So the jfets look good. Back to the board then.
What are the voltages at the top and bottom of R9 when there is NO jfet installed at all? They should be the same and close to 20 volts.
Turn off power. With your ohmmeter, and NO jfet installed, verify that the resistors between each jfet and ground (R21 to R24) are indeed 10 ohm each.
If all is good, next verify consistency in your measurements. Solder ONE jfet and measure Q3 (all 3 pins). Remove the jfet, solder another one and repeat.
Pierre
Old 15th December 2011, 04:22 PM   #1202
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
R9 Top = 20.42 Bottom = 20.27
R21-24 are all 10R . As for the fets soldering .... I use Q6 position for each fet
i test in situe ?
Old 15th December 2011, 04:26 PM   #1203
Pearl Two
Yes. In situ please.
Old 15th December 2011, 05:47 PM   #1204
1) 7.09 mA
T, 3.61
M, 10.01
B, 3.22
2) 7.08 mA
T, 2.59
M, 6.79
B, 1.84
3) 7.01 mA
T, 2.38
M, 6.77
B, 1.51
4) 7.18 mA
T, 2.20
M, 5.03
B, 1.86
I don't understand why the first one was that way and the others dropped .
Rich
T,
Old 15th December 2011, 06:08 PM   #1205
Pearl Two
Rich - Interesting. T, M, B means top, middle and bottom pin of Q3, correct? Something funny is going on. Let me chew on this for a while.
Do you think you could post a close up pictures of this area of the board (component side and solder side) ?
Pierre
Old 15th December 2011, 06:21 PM   #1206
nar is offline nar
nar's Avatar
Pierre
Pierre - yes, definitely there is something strange going on here. I'm puzzled
Let's wait for Rich pictures. At least, his camera works very nicely
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 15th December 2011, 06:21 PM   #1207
Pearl Two
nAr - Yes there definitely is a problem.
Got another idea. Wondering if the board is somehow applying voltage to the gate of the jfet.
Rich - Please would you short-circuit the input to ground, and re-measure Q3 (T, M, B) with one jfet in Q6? And please would you measure the gate (middle pin) of the jfet in Q6. It should be at 0 volts. If it is not, we may have found a problem.
Pierre
Old 15th December 2011, 06:26 PM   #1208
nar is offline nar
nar's Avatar
Pierre
Yes, gate should be close to Ground
nAr
Old 15th December 2011, 06:48 PM   #1209
with short across input , Q6 Gate 0 VDC
Q3, T = 17.49 VDC
M = 10.11
B = 17.36
Old 15th December 2011, 07:10 PM   #1210
nar is offline nar
nar's Avatar
The resistor left to the R8 (seen on top^) ; on the 2 sides, bottom solder joint of R looks bad
nAr
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
