Pearl Two
Pearl Two
Old 6th December 2011, 04:23 PM   #1101
nar is offline nar
nar's Avatar
Originally Posted by richluvsound View Post
I have been checking voltages against Schematic .... ?
I have a flickering LED on one board .Measuring is nigh on impossible ? I have tried tracing it back ,but I'm at the edge of my knowledge .
On the other board I have a drop on Q3 ... I should be reading 10 VDC and I'm getting 1.3 VDC
Also , setting P1 ? I have + on pin and - on PAD ground is this correct , If so, why is my meter all over the place ?
HELP PLEASE ?
Rich
Please do some measures again and post. Rails, and other parts.
I assume you talk about led Vref so I also assume you talk about Pearl II
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 6th December 2011, 06:02 PM   #1102
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Hi Nar ,
just been on skype with 6L6 . We took all the measurements . He will
post shortly for your input . ME ? .... I'm just doing as I'm told !
Rich
Old 6th December 2011, 06:04 PM   #1103
nar is offline nar
nar's Avatar
OK. I will check the board from time to time
nAr
Old 6th December 2011, 06:34 PM   #1104
wayne is offline wayne  United States
In the hills
Pearl Two
Default Pearl 2 Voltages
Corrected voltages on the schematic. 6L6 pointed out I had a negative voltage exceeding the supply.
Old 6th December 2011, 06:51 PM   #1105
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pearl Two
programmed current for positive shunt reg : 60mA
programmed current for negative shunt reg : 30mA
per channel
back'o'napkin calc of exact Iq , per channel :
positive leg : 4 x 5mA + 3mA + 2 x 1mA +10mA= 34mA
negative leg : 2mA + 4,6mA + 10mA = 16,6mA
edit : presuming that each input Jfet is in 5mA ballpark
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 6th December 2011, 07:51 PM   #1106
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
After a long skype conversation with Rich and a quick phone call to our esteemed Mr. Colburn, it's a good guess that Q2 (the ZVP3310) is inoperative.
However, as I am sitting here typing this, I got an Email from Rich saying that he replaced Q2 with a new one and the measurements are basically the same...
The rails are fine, at + and- 24v. There is a little low voltage around Q3, 7.9 base / 7.3 collector / 7.2 emitter .
The big problem are the voltages around Q2 -- they are +23 drain / +19v gate / -23.8v source. This is not good, as there should be zero volts (or close) on the source.
Also, the measurements around Q11 are -23v base / -23.8v collector / -23.9v emitter.
Old 6th December 2011, 09:13 PM   #1107
In the hills
Pearl Two
Do we have good grounding on this unit? Is C9 in place? If it is oscillating measurement will be difficult.
Old 6th December 2011, 09:38 PM   #1108
nar is offline nar
nar's Avatar
I also think about an oscilation issue. If pot can't be adjusted it looks like a symptom.
The ZVP wouldn't need compensation cap, it can even make the circuit oscilate in some cases
Best,
nAr
Old 6th December 2011, 09:56 PM   #1109
6L6's Avatar
Pearl Two
I didn't ask if C9 is installed.
The PSU is grounded to the mains as shown in the article, through the bridge. The Pearl circuit board is not in a case, nor are the signal leads hooked up.
Would oscillation cause the negative rail to appear at the source of Q2?
Should the input be grounded for testing? And/or the output?
Old 6th December 2011, 09:59 PM   #1110
C9 is installed .... !
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright ©1999-2017 diyAudio
