Pearl Two
Pearl Two
Old 4th December 2011, 03:32 PM   #1091
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Originally Posted by Tea-Bag View Post
240V Line IEC ----CL60---CL60---Trafo Red wires..
N-------------------------------------Trafo Black Wires
Bags ,
AC + before fuse .... then on the + of both secondaries before diodes ? Same as my amps basically ?
Rich
Old 4th December 2011, 03:47 PM   #1092
Tea-Bag is offline Tea-Bag  United States
not politcally affiliated
Tea-Bag's Avatar
Pearl Two
Right, Mine are after fuse. But I didn't need one on my Pearl2, but my reg is different.
I dont think it makes a difference, as long as they are there to slow the current coming in on the primary side
Old 4th December 2011, 03:59 PM   #1093
nar is offline nar
nar's Avatar
Thar can also be done this way:
IEC phase - fuse - cl60 - one leg of primary
Other leg of primary - cl60 - IEC neutral
Always have Earth from IEC directly to chassis ground by short thick wire.
Never defeat Earth to chassis connection.
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 4th December 2011, 04:16 PM   #1094
Got it down to 500 mA with one CL 60 before fuse . So I can put another on primary Neutral and try a 250mA ?
Old 4th December 2011, 04:59 PM   #1095
nar is offline nar
nar's Avatar
Seems you have a 50VA xformer.
50/230= 0,217A more or less
This is the max current your xformer is intended to draw from the wall more or less
So, try adding another CL60 to the queue And pop in the 250mA slow blow fuse, be brave. If it stays still after 10 power on, then it's probably fine.
Pearl would never consume that amount of power anyway; you have high voltage film caps at the output, so even your DC coupled preamp wouldn't be destroyed in case of malfunction. I guess 250 mA slow is a pretty safe value.
If you can plug multimeter on Mains series with your circuit, (caution when doing this !!! Mains voltages can be hazardous) you can visualize the AC current draw on the line. Theroritically you could even go down to a 100mA fuse for a 50 mA continuous draw. After that all needed to know if the circuit has a biggest current draw at turn on ...
Circuit Ground can also be wired to Earth (Chassis) through a diode bridge. Or even diode bridge and cap paralleled I guess if noise issues.
Best,
nAr
Old 4th December 2011, 06:44 PM   #1096
Thanks Guys .... it appears to working fine with 2 x CL60 in series with 250mA fuse .
Next step Please ?
what did I learn today .... AC divided by VA = A of fuse needed ?
Rich
Old 4th December 2011, 06:58 PM   #1097
nar is offline nar
nar's Avatar
Next step Please ?
Rich
Nope atoll .
VA Rating VA / AC line V = I A draw @ max. xformer current
It is the equivalent in AC to the Ohm law I = P / U
Next step ? Have you done the I/Os, and maybe ... listen to it ???
Glad to hear for the 2 CL60 working together
Best,
nAr
Old 5th December 2011, 01:43 PM   #1098
Wellerman is offline Wellerman
I will be using the original PSU schematic from Wayne (2x24V transformer in my case). Would thermistors be a good idea in this setup too? Where in the schematic would I have to mount these? (I see a max C of 1250 uF @240V AC for the CL60)
Old 5th December 2011, 03:45 PM   #1099
I have been checking voltages against Schematic .... ?
I have a flickering LED on one board .Measuring is nigh on impossible ? I have tried tracing it back ,but I'm at the edge of my knowledge .
On the other board I have a drop on Q3 ... I should be reading 10 VDC and I'm getting 1.3 VDC
Also , setting P1 ? I have + on pin and - on PAD ground is this correct , If so, why is my meter all over the place ?
HELP PLEASE ?
Rich
Old 5th December 2011, 07:58 PM   #1100
nar is offline nar
nar's Avatar
Sorry, PC is off, work tomorrow, I'll try to look by tomorrow evening.
Best,
nAr
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
