Pearl Two
Pearl Two
Old 30th November 2011, 06:31 PM   #1071
richluvsound is offline richluvsound  United Kingdom
richluvsound's Avatar
Hi Zen,
these fets were sent me by Wayne .... I assumed they had been matched .
Rich
Old 30th November 2011, 06:38 PM   #1072
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Pearl Two
then even worse , because we can't doubt jfets came from that direction
now is time for learning ; desolder , one by one , each semiconductor and test it
bjts with diode test , jfets in testing/matching jig
it really doesn't pay of , when you troubleshoot circuit randomly .
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th November 2011, 06:55 PM   #1073
I have this made up for testing IRF240 ,but never sure i was doing it right ?
I have a variable DC power source ..... how many VDC for these little suckers ?
Old 30th November 2011, 07:20 PM   #1074
Zen Mod's Avatar
Pearl Two
search through forum
"testing jfets"
or search through Papa's articles
Old 2nd December 2011, 12:46 PM   #1075
nar is offline nar
nar's Avatar
A simple way is to go for their IDSS without any RS (Source resistor) because jfets self bias pretty easily.
A 9V battery, and + to drain and - to gate/source shorted together. in series you put the mA meter, let them idle and just read values
For P types, just reverse the battery polarity
Best,
nAr
"... Audio needs the thinnest wire ..." Rowan McCombe ... I hear it !!!
"Just 'cause they can't hear or sense it themselves doesn't mean you can't !" Allen Wright Allen was right ...
Old 2nd December 2011, 12:55 PM   #1076
nar is offline nar
nar's Avatar
Originally Posted by richluvsound View Post
I keep blowing fuses .... I have checked one board and I'm with 1.5 VDC .
I unplugged it and plugged back in ... LOL fuse blew . Would an NTC across the
IRC stop it ?
I'm going to check the other board against the Voltages I have from Wayne . I'm checking one board at a time - the other board just blows the fuse as soon as I power it up !
Any guidance would be greatly appreciated
Rich
Check for shorts on the faulty board first with continuity meter. Probably a solder joint touches somewhere it shouldn't ...
The read values seem fine at a quick glance except the -26.2 V at led reference point. Obviously value reading here should be : about 1,6V - 1,8V across LED1. Or, -22,4V to -22,2V between up leg (seen on schematic) of the LED and GROUND.
Best,
nAr
Old 2nd December 2011, 09:47 PM   #1077
Thanks Nar,
I have removed all the active parts and checked voltages after regs and all good ...
I will test Jfets tomorrow . I have a transformer that will give me 9.75 VDC
will this be ok to use ?
best, Rich
Old 3rd December 2011, 02:20 AM   #1078
6L6 is offline 6L6  United States
6L6's Avatar
Pearl Two
You should use a 9 volt battery, because you need a fairly stable DC power source. If you have a good adjustable bench top power supply, you could use that, but a battery is a very good substitute.
Old 3rd December 2011, 02:05 PM   #1079
Ok , now I have got 6L6 lost too ... when I wire one board at a time to PSU all good ,but when both are wired the fuse blows ( no actives on either board- all voltages are good post Reg ) . I'm sure that .250 mA is advised for 240 AC - 3.15 at IRC
6L6 has checked pics of wiring and confirms its correct . I'll put some on here if needed .
Thanks , Rich
Old 3rd December 2011, 03:01 PM   #1080
Photos of wiring .
Pearl TwoHide this!Advertise here!
Another diy-pearl... lykkedk Pass Labs 18 15th June 2007 04:44 PM
ono or pearl PCB's mantisory Pass Labs 1 28th September 2006 11:12 PM
Pearl need help dzkh63 Pass Labs 1 26th September 2006 03:16 PM
WTB: Pearl PCB aire Pass Labs 1 26th February 2006 10:51 AM
Copyright ©1999-2017 diyAudio
