B1 Active Crossover - Page 15 - diyAudio
Old 19th January 2010, 09:38 AM   #141
njepitt is offline njepitt  United Kingdom
Originally Posted by cviller View Post
Ok, I have done a quick sketch and I would like to hear what you guys think - is this completely insane or something that could end up being really cool?
There is a volume control for each channel - I would probably use double pots for stereo.
The filters are going to have dip switches so that the cross frequency can be set without too much trouble.
The headers J1-J6 are intended to be expansion slots where additional filters can be added (to get more than 12db slopes). I thought I would use jumpers to short them out when not in use.
As you can probably see, I have been very much inspired by B4 and XVR1...
Hi cviller,
I took a look at your schematic and I'm a little confused.
1. I can't see the filter caps and resistors.
2. Jacques' original circuit has one more buffer in each branch of the filters, with volume pot only *after* the filters. This appears quite different from your proposal, which has them before the filters.
3. Can I point out posts #24 and #74 , which have an important adjustment inthe original schematic (and addition of another buffer in the LP section). Does your plan include this and I misunderstood? Or have you found another way around the problem?
4. I like the idea of making the board enough to do a three-way, but how much does the discussion above on the LP section affect the band-pass section in your design?
5. (Dumb question, maybe) What do you mean by a dip switch?
Cheers
Nigel
Old 19th January 2010, 10:33 AM   #142
I would not put a 6channel volume pot after the input buffer when a 2channel volume pot can do the job just as well.
Adjustments in the 6channels to balance out gain and sensitivity variations should be done at the output of the filters, but before the final line driving buffers. Some of this (fixed) adjustment can be built into the power amps if the gain required in one frequency band is much different from all the others.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 19th January 2010, 02:08 PM   #143
cviller is offline cviller  Canada
cviller's Avatar
Originally Posted by njepitt View Post
Hi cviller,
Nigel
I can see that - the blocks of filter sections need to be drawn, but what I have made is just the "conceptual framework".
Old 19th January 2010, 02:29 PM   #144
cviller's Avatar
Thanks for you comments Andrew! I know you don't like too many pots.
I see it this way (for a two way full range with woofer): Normally, I would have higher efficiency on the fullrange, so I'd need to attenuate the highs - ok no need for pot on LP. This would also work if I decide to use an F4 as driver for the woofer. But right now I use a chipamp for the woofer, which has more gain than the power amps I build - in I case I would also need a pot on the woofer. But I can't take the pot away from the HP. I know I can adjust the gain on amps, but I would most likely use this XO on both home-brewed and borrowed amps, so I would lose a lot of friends this way...
Your other point about the placement of the pots is interesting. I expect your rationale is: "why throw away gain before filtering - this will hurt SNR". This is a good point, but I just copied what I saw (and heard) here:
DIY progress report
But if I did move the pots in the end, I would have to add yet another buffer stage.
Old 20th January 2010, 05:25 PM   #145
dviswa is offline dviswa  United States
cviller,
I would love to see what you will cook up. BTW, have we dropped 2sk170 in favor of BF862?
Dinesh
Old 20th January 2010, 05:36 PM   #146
cviller's Avatar
The bf862's are really tempting. You can get 100 for $22 and if they perform as good as 2sk170 I think they are worth some design effort.
I probably have to start a new thread soon...
Old 20th January 2010, 06:02 PM   #147
I'm using the BF862s, and the buffers that are up and running sound great. YMMV, of course... It may be worth remembering that juma used the BF862's on little adaptor boards, which could be used on a PCB designed for 2SK170 if you wanted to.
Cheers
Nigel
Old 20th January 2010, 06:52 PM   #148
I got 200 off 2sk170 for $34 and delivered to the door.
regards Andrew T.
Old 20th January 2010, 09:00 PM   #149
udailey is offline udailey  United States
Andrew,
Cheapest I can find in the states is Mouser at 22 for a hundred.
Where did you find yours?
Uriah
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
Old 21st January 2010, 11:03 AM   #150
Spencer has a thread offering 2sk170bl in swap meet.
regards Andrew T.
MOX - active crossover moamps Analog Line Level 242 3rd March 2017 07:14 PM
MOX active crossover buy tiroth Group Buys 262 11th September 2014 08:24 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright 1999-2017 diyAudio
