Old 2nd December 2009, 06:53 AM   #1
revintage's Avatar
Default Preamp with more Aleph than Zen-style
Not quite true even this one has a slight resemblance with the inputstage of an Aleph.
Anyway less problematic than the Zen-style pre I showed in the "2SK170 limit"-thread as Zin is high here.
Distortion will prove to be extremely low, well below 0,05% at 6V out at 6dB gain. Sims say 0,0006% but I wouldnīt count on that even if distortion figures for the other versions has proven right.
This one will also have a upper -3dB point that is many times higher than the Zen-style.
Clipping at over 13Vrms out into 10kohm.
We will just hope for that it sounds right.....
Brgds
Lars
Old 2nd December 2009, 01:35 PM   #2
revintage's Avatar
The 8.2V zener can/should be substituted by a string of four 2.1V red LEDs.
Brgds
Lars
Old 2nd December 2009, 03:33 PM   #3
Johnloudb's Avatar
Very Nice design! I like the Miller compensation you did with C2. Protects the transistor of excessive voltage swing too, I guess. Why did you choose active biasing instead of resistor bias? Apart from better noise rejection, does that help performance? I usually resistors bias because people say it sounds better, but who knows.
Old 2nd December 2009, 06:18 PM   #4
revintage's Avatar
OK, it can be made all R. But due to the higher loading we will probably reach 0,1% THD at 6Vrms out into 10k. If we substitute the right drainresistor with a cheap Hammond 150H/8mA we are on track again. No we should get at least 11Vrms out at same THD as above with predominantly 2nd order overtones.
C1 in the first schematic is only for making the input resistor to behave like a SF.
Brgds
Lars
Old 3rd December 2009, 10:00 AM   #5
revintage's Avatar
As this still is at the design-level I have done some side-by-side sims. This to get to know how FETs work having only used them as CCS´s before. Used two known and appreciated designs and adapted my circuit to one of them in terms of voltages and current. Can´t say I am dissapointed as this moment.
I am now only waiting for my 2SK170s, IRF610s and 2SK322s to arrive. Listening and measuring IRL still is king. Will first of all try the chokeloaded version mentioned above.
Brgds
Lars
Old 4th December 2009, 01:46 AM   #6
Johnloudb's Avatar
I was only commenting on C2 and that it provides a virtual ground at the drain of the input JFET. I guess you meant to say C2? C1 is just a coupling cap.
What does SF mean?
I've some BF862 JFETs and some IRF610s. Maybe I'll get one built first.
Though, very highly unlikely since I'm loaded with projects right now. Got to get serious and finish a speaker build I'm working on.
Old 4th December 2009, 06:11 AM   #7
revintage's Avatar
C2 that I of course ment is just a de-coupling cap. About SF, itīs short for source-follower.
BF862 has in my opinion to low voltage capability for getting adequate overload margin, so 2SK170 or 2SK223 is what should be used.
Brgds
Lars
Old 4th December 2009, 10:23 AM   #8
juma is offline juma  Serbia
juma's Avatar
Hi Lars,
the R15 in the middle circuit (post #5) should be 10R to 15R. With 100R the Id of that CCS will be too low.
Old 4th December 2009, 10:30 AM   #9
juma's Avatar
Originally Posted by revintage View Post
BF862 has in my opinion to low voltage capability for getting adequate overload margin...
That's true, but I'd rather cascode the BF862 (when higher supply voltage needed) then use the k170 which is (IME) sonically inferior.
Old 4th December 2009, 10:48 AM   #10
revintage's Avatar
Originally Posted by juma View Post
Hi Lars,
Hey Juma,
Adjusted Id for ca 12mA, at about the same current as the driver. Will probably not make so much difference sonically with higher current. Used the NXH model.
cascode the BF862
At what voltage would you bias the upper FET, with same voltage over both? Have one a few discouring theoretic examples with various gatevoltages at the upper FET. Donīt think I will build it but I am curious of the solution.
I donīt like them in the tube world where I have tried quite a few. Rod Coleman has a folded cascode concept, triode in the first and then a PNP BJT, that he says he likes.
Brgds
Lars
Naim style DIY Preamp Agisthos Solid State 4 15th November 2005 07:55 AM
Ayre style X-Preamp? aparatusonitus Pass Labs 22 22nd October 2005 12:12 AM
Choke for preamp to get battery style power supply? Sigurd Ruschkow Power Supplies 1 18th March 2005 07:55 AM
WLTB: Mark Finnis style Aleph 4 Pcb dhole Pass Labs 4 3rd February 2005 02:27 AM
So, what's your favourite ss preamp style? <m> Lisandro_P Solid State 6 27th March 2001 01:49 AM
Page generated in 0.11032 seconds (80.08% PHP - 19.92% MySQL) with 11 queries
Copyright Đ1999-2012 diyAudio
