diyAudio Retiree
Actually I do have an X preamp in the design phase. Not shown is the Fet follower to buffer the circuit from the volume control. The balanced part need to see equal impedance. i have a nifty servo that uses only 3 transistors and acts on the common mode offset and ignores the audio signal this should operate with lower distortion and 1 less cap than a servo for each balanced output as well as a greatly simplified circuit. This is a work in progress but someone could probably build one from this design with AC coupled outputs. The bais points and feedback are based on a pretty extesive study of Borbely's Jfet and Pass's mosfet preamp designs with several nested feedback loops. The Borpass preamp doesn't sound like a very enticing name and the Nerno preamp is absolutey out of the question!
There is about 10 hours of Spice analysis to get this far. The circuit is counter intuitive concerning output impedance. The preamp has to drive two (or one for nonbalanced amps and that was the problem) single ended loads with respect to ground at the amp input [ INSERT STEVE EDDY TRANSFORMER SPEECH HERE ] and the differential and common mode output impedances are different which was a real dilemma in the early design phase. I have never been forced to fight my gut level instincts conflicting with the Spice results like this one! Made me nuts for two days trying the resolve the difference. It also lead to a very interesting dialog with Mr. Pass on an op amp circuit that does not work and was posted on the forum. That hasn't stopped the op amp vendors from publishing it in some data sheets and app notes. Seems the original circuit required some coupling caps the op amp guys left out. I think even Mr. Pass was scratching his head on that one. |
#2 |
Hey Fred,
Good one, I had a look at the Borbely pages last night after readng your post. I also down loaded Mr Pass's article on diy opamps, its excellent and I really like the references to CCS which I will study carefully over the weekend. Borbely also has an updated CCS using just two fets and one resister!! I will have a closer look at your design when I clear the bench of the X Aleph and my new re built BOZOZ. Ian |
#3 |
diyAudio Editor
Hey Fred, That's awfully nice of you to share. Interesting (tempting?)
"There is about 10 hours of Spice analysis to get this far." You have to admit that shows developing stuff isn't a matter of just plugging into a modeler Ian : Is that mudcake stuff a strine(sp?) expression or are you referring to the washing? I think they use an ultrasonic transducer hooked to the Aleph to do the wash up there. I did once hint to Cyclotron Guy that maybe I could drop by to take the tour of the Pass labs Research and Production world headquarters. He responded that the complete tour would take about 30 seconds, but didn't say they would refuse to let me enter
#4 |
By the way this is a bit off topic but its still progess, I tried to X the BOSOZ last night.
Gee what a change. Has anyone else done the conversion recently? At the moment I'm evaluating dual CCS (Aleph style) in normal BOSOZ mode.. The short answer is if it ain't broken don't fix it. Ian |
#5 | |
Account Disabled
What about a new separate thread? JH |
#6 |
Na Na,
I put it in the X Aleph Thread like a good little Boy.......well worth a try...Muahhahahahahh. As mentioned earlier too early to say about X BOSOZ ..but .My neighbours can hear the the dymamics I'm sure. What happens when you (X) x (X) = Rub the Magic......L.........Big Balllllaaaboooong............., I mean Boommmmm....... Like Bruce Wllis said I know Boom. Time for Peanut Butter & Chocolate...yummy. Ian |
#7 |
Ian:
How did the Aleph CCS's work on the BOSOZ? This is one of my favorite combinations. I am not convinced that we know how to draw an X at this point, plus, as the master said; "not all amplifiers should be Xed." __________________________________________________ __ The laws of physics always apply. The real question is; which ones this time? Tmac |
#8 | |
You can read my description in the two first posts on this page: x soz
Henrik |
#9 |
O'kay,
I'll post back here for now sorry to confuse you all. The results of my Sunday school readings... It took a while to arrange the CCS and re jig the pre for X BOSOZ. The setup..... X BOSOZ exactlyLike Hendrik, 10K on inputs, 39K feedback - in to + out, + in to - out. The - in is taken to earth at the node of 10K and the attentuator.(Thats another story 23 position switch from some special!!) The CCS is irf 610 on good heatsink (like mini Aleph bloody hot mate) + 220R on gate, 9.1 v zener bias 10K to earth and about 60R on the source to about -58V The CCS is common to both active Fets (610). This gives about 75ma total current. So what happened..... Okay BIG BulllaBooooooom Running the Aleph 2..........Woooooooooooooooooow. I like the results, accuracy, natural and very listenable. thats a hard nut to crack! XBOSOZ with active ccs......10/10 The spatial delineation is very impressive, there is a nice holograph, and the silence between the notes on solo Piano is outstanding. With the X BOSOZ resistive ccs Nice width/depth and drive, but there is some Smoke on the Water, the sound seems to be fighting itself, aiming for purity but not quite. I find it distracting. The BOSOZ with resistive ccs. Well we all know that sound, just like your aunts favourite plum pudding....yummy, engaging, warmth and soothing. The analysis There would appear to be close correlation between the use of active CCS and X topology , and the the use of std Fet diff pair and resister tail. The BOSOZ to me and the resistive ccs of 1500R tail has a nice synergy with the end sound, ie they mate well. So does the X BOSOZ with the active CCS desribed. But X BOSOZ with the resistive ccs tail is less together in totallity of balance....like smoothy Peanut Butter but taste a bit strange. The resistive ccs seems to add a nice skin to the sound, the X is cancelling everthing but the skin is still there, so that is confusing the mind. The active ccs removes the skin and the X cancels everthing and it sounds complete. With std BOSOZ, the skin is there and the warmth, I think they complement each other. Hope all that made sense. Sunday school is over. Ian |
#10 | |
Account Disabled
Intersted, dazed and confused. Your opinion is quite different from Henrik's. You praise X BOSOZ with the active CCS while Henrik does with the resistive CCS. The difference I see is that yours is X BOSOZ + Non-X Power while Henrik's is X BOSOZ + X Power. And, confused with the threads on mixed subjects... JH |
| Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps | MartyM | Tubes / Valves | 3 | 16th October 2008 04:52 AM |
| Guitar Preamp = MIC Preamp = other preamp ,,are they all same? | Paswa | Solid State | 1 | 12th March 2008 05:16 PM |
| twisted pear Preamp/other suggestions for Preamp kit | LukeDuke | Chip Amps | 1 | 1st February 2008 09:57 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| wiring preamp outs on a preamp | bonsai171 | Solid State | 4 | 22nd March 2004 10:13 PM |
| Page generated in 0.11629 seconds (85.66% PHP - 14.34% MySQL) with 11 queries |
