Have not worked with 2SK170 at high B+ before. For a future Zen-inspired preamp-project I intend to use it like below with B+=90-100V, Vd=35-38V, Id=8mA. This is quite close to the limits of 40V/10mA.
Will there be any immediate risk of frying it due to the high B+?
Brgds Lars |
#2 |
the high Vds of 35V combined with the medium Id current of 8mA requires a junction dissipation of 285mW. That's 71% of maximum rating. Far too hot for continuous duty.
regards Andrew T. |
#3 | |
Is this something you have found out empirical as this info is nowhere else to find? Toshibas datasheet only states 400mW at 25 degrees. Found another typical JFET where dissipation derating above 25degrees was close to 3mW/degree. Though my main concern was running B+ of two times max Vd, .
Brgds Lars Last edited by revintage; 29th November 2009 at 03:06 PM. |
#4 |
To clarify, my concerns are what happens at "power up" and "power down".
Brgds Lars |
#5 | |
OTOH, cascode is an easy way around the Pd problem (with additional benefit of characteristic's linearization and larger swing capability). |
#6 | |
Good idea, this is cheap stuff..... Maybe one should try a MOSFET capacitance-multiplier with long time-constant to get around the evntual start up problem and also get better PSRR. Will go singlestage Zen-style(not BOZ), cascode is two stage About linearity and swing this one with a single 2SK170 will put out ca 25Vrms into 10k(Zout below 500ohm) at 11dB gain with below 0,1% THD. This as shunt feedback is a lot more effective than current feedback commonly used here. Question though is if it will sound as good as the figures indicate
Brgds Lars |
#7 |
Valid concern IMHO. FWIW 2sk117 gives you another 10V to max Vds. Another way to deal with this would be to go the cascode way, by using a jfet with larger Vgs(off) on top. I use a 2n3819, but many others would qualify. My 2c.
#8 | ||
Zout will be Rd (6k8) || RLoad. THD figure is unrealistic too. |
#9 | |
Checked 2SK117 and unfortunately it had 25% lower dissipation. Otherwise it look good with much lower Ciss. About cascode this isnīt an option as I told Juma above that I donīt want to go two-stage
Brgds Lars |
#10 |
2SK223. 80V, 400mW.
Don't blame me if you fry one. Patrick |
| 2SK170 matching | audiodan | Pass Labs | 12 | 29th March 2009 07:40 AM |
| Wanted 2sk170 V | Sergelisses | Swap Meet | 0 | 28th February 2009 02:35 PM |
| 2SK170 pin configuration | Jan Dupont | Parts | 9 | 22nd October 2007 06:45 AM |
| 2SK170 successor | djmiddelkoop | Parts | 3 | 22nd March 2005 01:16 AM |
| Ono - 2SK170, Which Idss? | transducer | Pass Labs | 11 | 25th March 2003 10:29 PM |
| Page generated in 0.10923 seconds (79.26% PHP - 20.74% MySQL) with 11 queries |
