Old 27th November 2009, 06:14 PM   #1
Default Ixys depleationmode fet susy one stage balanced pushpull Zenitronamp.
Click the image to open in full size.'
I just posted about this amp in another thread but i wanted to open a new thread about this amp.7
I read about Ixys having a high power depleationmode fet, and i got realy intressted. Thiis is what i would like to build.
I can not imagine a better topology for a ultrasimple amp.
Its a supersymmetric fully balanced one stage pushpull amp. Quite a mouthfull to say!
We live in a horizontal world, why use vertical topologies???
Old 28th November 2009, 09:16 AM   #2
Johnloudb's Avatar
That looks like a really interesting design. I like it. To be honest I'm having a little trouble following this. Are you saying it's a super symmetric Circlotron?
Okay, I see the two circles, and the susy feedback. Looks like the 33 ohm resistors set the bias current? I'd love to see this built. Good luck!
Old 28th November 2009, 11:56 AM   #3
Default Iwas going to write more about it yesterday...
Its a supersymetric circlotron amp. The two 33 ohm resistors just make a groundreference point. Nothing else.
Bias is set by the depletionmode-fets and the DC-resistans of the big inductor.
The bifilare inductor does two things. It isolates the Sources from the drains on the Fets so they can provide voltage-gain, and it provides a I/V converting - like a constant currentsource or a powerresistor does in an normal Zenamp.
Here is a simplified version, with power-resistors instead of inductors.
I have left out bias-arrangement for clearity.
Old 28th November 2009, 11:58 AM   #4
The connection between the sources of the Fets is the same thing as in a LTP. Its basicly a circlotron-LTP (Long Tailed Pair).
Old 28th November 2009, 12:05 PM   #5
I have been building different Circlotons since 2001, and i came to think of this one when i read Nelson Pass Zen V-7. Its in many ways the same amp but with floating supplies and no need for any CCS to set the currentflow though the devices.
I guess i could call it The Circlotronic Zen V-7.
A diffence from the Zen V-7 is this amp will runn in class A/B, but with a lot more distortion. I got something like 50 watts out of this circuit with 2 x 15 volts supply and 500 mA quisent current tjhrough each Fet.
Old 28th November 2009, 12:08 PM   #6
R1 and R2 could be powerrestors, lightbulbs, constant current sources or Nelson Pass Aleph current source.
I have drawn versions with SRPP and cascode and almost every possible variation. But i like simplicity a lot better.
Old 29th November 2009, 11:54 PM   #7
Ejam is offline Ejam  Australia
Default What is the DC Resistance of the Inductors?
Circlomanen
What is the DCR of the 150mH inductors?
Ejam
Old 30th November 2009, 12:54 AM   #8
Badge is offline Badge  United States
OK, a few basic questions. What is the rated power output? Can the power be upped by increasing the voltage?
The freaks stick together, they are a tight old crew
Old 30th November 2009, 06:45 AM   #9
If i remember correctly, its about 0,6 ohms. Maybe a bit high for the Ixys depletion-mode-fets.
I dont know the rated output. It can be scaled up or down as you want. With 20 volt supplies and 2 amperes of current through each fet, i can get a clean 20 watts, but it will give about 50 something watts before clipping. The distortion rises a lot when leaving class A.
With really powerful devices and a lot of heat-sink you could probably get 100 watts out of it. But I haven't tried that.
I have to buy some fets before i can build this one. I have built a similar design with IRFP250 before.
I was going to build one with normal Hexfets this past weekend, but i was to tired, so all i manged was this thread.. I hope to get some time in the near future.
Old 30th November 2009, 07:51 AM   #10
bobodioulasso's Avatar
150mh must be a big coil?
May we have a pic?
Balanced Zen v5 + balanced Zen line stage Adrie Pass Labs 0 30th May 2004 05:27 PM
Balanced Input Stage Bukitoo Solid State 5 11th March 2004 03:03 AM
Balanced DC servo for balanced stage ? CheffDeGaar Solid State 8 9th July 2003 02:39 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
balanced zen line stage supernet Pass Labs 3 13th December 2001 06:10 PM
Page generated in 0.10429 seconds (79.94% PHP - 20.06% MySQL) with 10 queries
