Old 15th March 2010, 09:02 PM   #421
I have no idea of Proop's sink and ambient data.
But we can start with some assumptions to show what we might expect to see.
Ta=21degC
Rth s-a = 0.5C/W
Rth c-s = 0.4C/W
Power dissipated @ 0.6Vbias = 30W
Delta T s-a = 30 * 0.5 * de-rating Factor (try 1.3 for dT=15C) = 19.5Cdegrees.
Delta T c-s = 30 * 0.4 = 12Cdegrees.
For 0.71Vbias the dissipated power rises to 35.5W
Delta T s-a = 35.5 * 0.5 * DF (try 1.28 for dT= 17.75C) = 22.7Cdegrees.
Delta T c-s = 35.5 * 0.4 = 14.2Cdegrees.
The data for these sets of Vbias assumed conditions would be
Vbias=0.6 Ts= 40.5degC, Tc= 52.5degC
Vbias=0.71 Ts'=43.7degC, Tc'= 57.9degC
One can insert the data for one's own hardware/ambient and predict (model) the temperatures to be expected before one even buys the hardware.
In this case increases the bias current by 18.3% should increase the FET temperature by ~5.4Cdegrees. From there one can estimate the reduction on SOAR for the higher bias.
regards Andrew T.
Old 15th March 2010, 09:44 PM   #422
Renron is offline Renron  United States
Renron's Avatar
Thanks Andrew.
"If it doesn't work properly, hope it catches on fire"- Nelson Pass @ BA3
Old 15th March 2010, 10:35 PM   #423
Ta=21degC
Rth s-a = 0.5C/W
Rth c-s = 0.4C/W
F5 power amplifier
post #7367 last measurements
post #7305 The amplifier heatsink 280x280x70-40
ambient 20.5 oC
this type of fins
Old 16th March 2010, 09:58 AM   #424
Originally Posted by bear View Post
vitalica,
I was wondering a few things...
what do you hear as the difference in the sound between the balanced and regular?
My friend who is a pianist says the sound is very neutral, especially the voices feel the difference.
what did you use for the resistors in series with the Mosfets?
Output MOSFETS are 2SK1530/2SJ201.
Source resistor 0R22 & 0R18 respectively.
whose balance schematic did you use?
The scheme is of Patrick (EUVL) - XF5.
I thank you very much for the help of the PCB and comp
what are those three pin devices that are in the front on the bottom??
Can you tell me exactly what you mean?
and finally, after how long did you measure the temperature of the heatsinks??
I too thought they might not be large enough and/or perhaps in that orientation they would not work so well...
Did I answer yesterday because I wanted to measure once again
I left the amplifier to function without signal 3 o'clock.
Over a time temperature was 45 degrees
50 degrees in two hours
more than 3 hours 54 degrees.
Do you think we should see what happens more than 5-6 hours?
Oh, you said "2A" bias - measured how?
I measured the voltage drop 0,22R (0,44V)
_-_-bear
Forgot to mention - very nice looking job!
Old 16th March 2010, 11:18 AM   #425
alazira is offline alazira  United States
alazira's Avatar
I think those are diodes, part of a bridge rectifier.
Old 16th March 2010, 11:30 AM   #426
Yes, I MUR 3060
Old 11th April 2010, 08:54 PM   #427
a.wayne is offline a.wayne  United States
a.wayne's Avatar
.. revival .......................................
Old 11th April 2010, 09:51 PM   #428
jackies is offline jackies  United States
You mean necroposting?
Old 12th April 2010, 02:20 AM   #429
tinitus is offline tinitus  Europe
noone are interrupting anything
Old 12th April 2010, 01:44 PM   #430
bear's Avatar
without revealing too many "secret details" over this way a number of experiments have been run regarding the power supply rails to the front end of the F5. It is daunting. Changes in that path appear at this point to radically effect the sound presentation!
FYI, and FWIW...
Anyone who wants to post pix of their competed F5s and comment on their sound may feel free to do so...
_-_-bear
_-_-bear
http://www.bearlabs.com ...live within ~60mi of Albany NY? contact me! --
NX150 listening impressions rabbitz Solid State 30 25th October 2006 12:27 PM
Listening impressions and recommendations? kk74 Multi-Way 0 31st December 2002 06:51 PM
Page generated in 0.12007 seconds (81.12% PHP - 18.88% MySQL) with 11 queries
