Blew a couple of Bussmann Series GBB Very Fast Acting GBB ceramic fuses when I repaired my Thresholds SA/1.
Can't find these fuses in Europe but a German manufacturer has ceramic alternatives only in slow blow version. According to Thresholds specs the SA/1 needs two 20A railfuses and one 6A AC fuse with 220 Volts. What would be the equivalent in the slow blow version? Thse amps have no softstartup feature in them and one of the Heinemanns on/off magnetic circuitbreakers kept tripping so now and then on startup. I inserted in every amp the biggest Inrush Current Limiting Thermistors, the MS35 10018 from Ametherm Inc. Now tripping on startup is over. Before that I used to startup both amps with a 10A Variac with Volt- & ammometer and I have been continuiing doing so to avoid (I think) stressing the amp at startup. When the dial is at 220 both amps take together approx. 3 to 4 amps continiously tapering of to 2,2 amps when all warmed up. When driven hard into my Acoustats 2 + 2, the meters in to the right corner (red figures + 3dB), it never rises above 5 amps intake. Is it wise or not to just keep on continuiing the use of this Variac to startup the amps? My wife finds this procedure akward, so whenever she's alone I arrange to have the Variac already in the 220 Volt setting so she can switch them on us usual and the Inrush Current Limiting Thermistors come in handy now. Last edited by BrianEno; 24th November 2009 at 10:55 AM. Reason: Misspelling |
#2 |
if you must use slow ones , de-rate them in A at least 30% ;
leave inrush thermistors in , use variacs for something else if needed - use thermistors with more ohms ..... some PA amps use even 100 ohms WW's in soft start
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Thanks for the answer.
My friend has a Levinson HQD system with eight ML-2's and het powers them up with a 30 Amp Variac,. The ML-2's have a soft startup circuitry, a relais and a powerresistor, but he insists on using a Variac to minimize the stress at startup. I always thought it was silly but having had problems with the Thresholds that originally have no soft startup circuitry at all, I thougt why not. I wonder what are the basic cons and pros for using a Variac every time. I'm really curious and openminded about this issue. |
#4 |
Wonder if you are the Brian Eno... nah, that would be too much of a coincidence.
Anyhow, I disagree with the former advice. I would suggest that you build a circuit that consists of a large power relay, a time delay circuit (a variety of simple ways to do it), and a large power resistor. The plan is simple enough. When you turn on the amps, via this "box" the AC mains is run through a power resistor(s) that limit the inrush current to some resonable value. Turns out that the value of resistor needed is typically about 8 ohms, might be double for 220Vac mains, use ohms law to check. Then after some seconds of time, controlled by the circuit, the relay pulls in shorting across the resistor, and returning your amp to a direct connection to the AC mains. This is significantly better, imho, than keeping any sort of current limiting device in series with the power going to the amp. Personally, I would prefer a very large variable autotransformer (Variac) to a Thermistor, if those were the only two choices. _-_-bear
_-_-bear http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. -- |
#5 |
Thanks bear,
All my Rowland, Krell and Levinson amps had these provisions you describe. Threshold opposed to these circuits because the contacts of the relays became contaminated. If you examine the circuitboards of the later E series Thresholds (1988 and onwards, SA/12e etc..) on top of the capacitorbank you see 4 thermistors (believe CL-60's) to do that job of inrush current limiting. The Aleph series used them also, do not know about the current series of Passlabs. Can anybody explain if there are any argumented objections against the use of Thermistors and/or Variacs for inrush current limiting purposes? My Megasurge thermistors drops immediately from 8 Ohms to negligible values even when I use a 1.5 Volts battery. |
#6 |
if thermistors are good enough for Papa , they're good enough for me .
| Replacement of tha WonderCaps in a Threshold FET/10 | Nounours18200 | Pass Labs | 25 | 19th November 2010 07:50 PM |
| DIY Variac | Tyimo | Solid State | 4 | 6th October 2007 11:18 AM |
| FS 10A variac | woody | Swap Meet | 8 | 16th May 2007 04:38 AM |
| Variac | ben goh | Solid State | 21 | 12th March 2007 06:42 PM |
| Variac? | Scribble | Pass Labs | 16 | 29th July 2004 02:12 AM |
| Page generated in 0.09281 seconds (81.12% PHP - 18.88% MySQL) with 10 queries |
