Old 27th November 2009, 05:38 PM   #21
EUVL is offline EUVL  Europe
Good to hear from you after a long while.
Though, the argument for the circuit in post #1 is that only a single non-floating power supply is required.
In the design you just posted, one still needs 2 floating PSU.
Not that that in itself bothers me.
Patrick
Old 27th November 2009, 06:08 PM   #22
Default Aha, i missed that one-powersupply thing...
With Ixys depleationmode-fets you could build this one.
But as you said, two powersupplies are needed.
The simplest fully balanced supersymetrical pushpull one stage-amp i can imagine. With big batteries as powersupplies no capacitors are needed at all anywhere in the amp.
We live in a horizontal world, why use vertical topologies???
Old 28th November 2009, 03:43 AM   #23
Paper mache horn fabricator
carpenter's Avatar
Thanks, I'll study and sim them in my spare time.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 29th November 2009, 03:33 AM   #24
I've beat Zen inductor amps to death ... Choke Loads for Zen/Aleph Amps
I ended up with toroidal 120mH 2.5A Amveco inductors. Since then, I run a source-follower output stage with an Aleph CCS.
Inductor amps still fascinate me, mostly because of the energy efficiency, but I've never maintained one in my system long-term.
Old 29th November 2009, 05:45 AM   #25
carpenter's Avatar
I'm afraid that inductor amps are all that thrill me. I, too, appreciate the enhanced efficiency. My most recent inductor, balanced, cascoded, follower is wonderful to listen to. It seems to have extra spring in the music, more life like. For a fellow that's hard of hearing, that bit of liveliness is hard to beat. Now, my wife, the golden ears, thinks the amp sounds excellent and is rather displeased that I've sold it. I told her I'll build us another very soon.
Old 4th February 2010, 12:08 PM   #26
Tyimo is offline Tyimo  Hungary
Hi Johannes!
The inductor is a bifilare winded big E-core transformer with about 2 x 150 turns of 2,5 mm2 isolated coppercable.
How much DCR has your big Choke?
How many Voltages did you set the Vgs for biasing?
Greets:
Tyimo
Old 19th February 2010, 09:13 AM   #27
0,6 ohm DCR. I dont know the voltage on the gate of the mosfets. I made it variable and set it to whatever voltage necessary to get 500 mA running through each fet. One ampere should be better.
Two amperes even better than that.
Old 19th February 2010, 06:47 PM   #28
Thanks!
Tyimo
Copper coil inductor vs. round core inductor tomchaoda Pass Labs 7 21st September 2011 04:42 AM
Simple circlotron amp bigwill Tubes / Valves 4 18th March 2007 01:57 PM
Circlotron djk Pass Labs 13 20th August 2006 03:19 AM
Supersymmetry Circlotron Circlomanen Pass Labs 6 18th April 2005 06:34 AM
Circlotron amps cuallito Tubes / Valves 7 25th April 2004 01:31 PM
Page generated in 0.08951 seconds (77.43% PHP - 22.57% MySQL) with 11 queries
