I'm thinking of building a battery powered BLS using 10 x 12V 5Ah SLA rechargable batteries. How long can the BLS last on those batteries?
#2 |
unless I forget something: to be on the save side: let's asume 4000mA hours. The BOSOZ draws about 160mA or the BOZ draws about 100mA. So the BOSOZ will last 4000mA/160mA hours = 25 hours, the BOZ about 40 hours. Regards, Thijs |
#3 |
Are these figures for both channels?I think the regulated BOSOZ ps should draw a fair bit of current seeing how hot it gets.With batteries maybe you wouldn't need the regulation and save on battery life. If you want to regulate you will have to adjust to something like 50v to work with your 60v rails.
#4 |
Yes these figure are for both channels. I could be a few tens of mA wrong but I don't think so. The active devices in the BOSOZ and BOZ indeed get hot due to the energy the dissipate (say 30V x 50mA = 1.5Watt) in combination with their high 'thermal resistance' which is due to thier low radiating surface. A small heatsink reduces the thermal resistance and hence temperature considerably. Regards, Thijs |
#5 |
..how will you recharge the batteries?
have you got a charger (schematic of a charger) Ralf |
#6 |
I'm presently using a 12V charger that charges 1 battery at a time for my buffered preamp (2 x 12V SLA). I've to find a way to concurrently charge all the 10 batteries (120Vdc). Any suggestions?
#7 | |
charging 12 batteries, one after the other - must be very time consuming. Can you desribe the sound differences between conventional psu and battery supply? Greets Ralf |
#8 | ||
For long lifespan Sealed Lead Acid batteries don`t like it being discharged completly. I wouldn`t recommend discharge them under 1/3 their capacity. So count for less operating time or go for bigger batteries. Quote:
Christoph STEAL the BEST - INVENT the REST |
#9 |
10 chargers! ... I need to reconsider if it's really worth using batteries to power the BLS (batteries VS PSU).
#10 |
I think the BZLS would work quite well on +- 24v , even Nelson has said it can work on 30v so it's not a big difference.
Of course you can up it to +- 36v with six batteries to be on the safe side and build only two chargers each charging 3 batteries.This could be a good compromise even though some do not recommend charging many batteries in series because of different internal R but I think it is not that critical and in the worst case the battery may have a slightly lower life span. In any case the sound quality will not be affected.I found that small voltage differences between battery rails and batteries on my battery powered gainclone do not affect sound quality. I think you have many options at your disposal. |
| Super Audiophile Phono-Stage - Battery Powered | GlidingDutchman | Analog Line Level | 41 | 6th November 2008 10:23 PM |
| balance zen line stage input and output | hc167 | Pass Labs | 10 | 23rd October 2006 03:29 PM |
| What happens if the battery supply is off balance ? | Will | Chip Amps | 3 | 6th October 2006 04:39 PM |
| Battery powered PC ? | percy | Everything Else | 15 | 7th March 2006 07:24 PM |
| Battery powered op-amp analogue stage of DAC | wreeve | Digital Source | 5 | 23rd August 2005 07:43 PM |
| Page generated in 0.10070 seconds (80.20% PHP - 19.80% MySQL) with 10 queries |
