ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230 ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230 - diyAudio
Old 9th November 2009, 08:36 PM   #1
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Default ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230
Here a new approach for an active crossover network (high pass): To get enhancement by the dynamic range in a very high quality audio system of one of my customers I have decided to introduce an active crossover network.
But the disadvantage is, that there are additional active components such operational amplifiers in the path of the signal.
But what about, if I use the ZEN topology itself as operational amplifier?
Because the ZEN isn't power source follower (it is a grounded source) I cannot use the "Sallen Key" topology. Instead of this I must use the so called "multiple feedback" topology.
But one disadvantage there is without additional operational amplifiers: a too low open loop gain. Therefore I have make a combination of both, i. e. active and passive network for the high pass.
The result is to see in the attachement. That work I have performed already 6 years ago. Now the PHL bass-midrange (Typ 1230) will be replaced by a pure midrange, again from PHL. For this reason, the crossover frequency must be increased to approximately 500 Hz and therefore I get back this single ended ZEN special amp to do this re-match. From this ZEN device I have make three photos (see below)
I would be interested to know whether there are experience with an active crossover by ZEN projects without additional operational amplifiers.
Thank you very much
File Type: pdf ZEN+active MFB+passive HP f-3db=270Hz.pdf (4.9 KB, 414 views)
File Type: pdf ZEN+active MFB+passive HP f-3db=270Hz.pdf.pdf (11.2 KB, 300 views)
Old 9th November 2009, 08:39 PM   #2
additional photos (please note: the power supply isn't include, it is a separate dual mono unit, installed on the wall behind a table
Old 10th November 2009, 07:35 AM   #3
Stefano is offline Stefano  Italy
Wonderful piece of work, tiefbassuebertr!
Let's make something special
Old 10th November 2009, 09:04 PM   #4
Allen Newby is offline Allen Newby  United Kingdom
Interestingly enough, I noted the similarity between the topology of discrete opamps and j-aleph, or my own variant, LTP Zen.
I was interested in the idea of using a zen amp with Linkwitz transform feedback to extend the lf response of a subwoofer.
Old 12th November 2009, 09:02 AM   #5
Because you use an additional differential input stage, there are more open loop gain than the orig. ZEN with only one stage, (voltage and current at the same time). Thus you can calculate as by normal op amp active crossover. Additional you can use two modes: the non inverted mode for "Sallen-Key" topology and the inverted mode for the MFB topology (multiple negative feed back). I would prefer the last for your fourth order acoustical 24db Linkwitz Riley high pass transfer function (12-18db BU characteristic actice crossover in combination with some passive components for mesured 24db Linkwitz Riley high pass transfer function).
Please note by creating of actice crossover - the Sallen-Key topology (multiple positive feed back) is only recommend for low pass function at low frequencies below approximately 300Hz (e. g. sub woofer), because the higher distortions there not critical.
Because a continuous control of the crossover frequency is easily to realize, this topology is used here in most cases.
Old 2nd February 2010, 08:13 PM   #6
Are there no others uses single ended power amps for tweeters and integrated crossover networks?
Old 19th October 2011, 09:30 AM   #7
in this case this thread is of interest:
http://www.diyaudio.com/forums/pass-...-speakers.html
Old 10th December 2012, 12:31 PM   #8
Telstar is offline Telstar  Italy
Interesting
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
ZEN include active crossover without additional OP AMP for ultimate sounding PHL1230Hide this!Advertise here!
Better-Sounding Active Crossovers Lynn Olson Multi-Way 166 5th August 2015 12:26 PM
ultimate crossover - help TheoM Multi-Way 5 25th October 2007 12:54 AM
Help me with my Denon POA1500(schem include) ostie01 Solid State 5 1st July 2006 01:20 AM
Active XO builders - Whats you ultimate opamp? ShinOBIWAN Multi-Way 0 16th March 2005 07:27 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Copyright ©1999-2017 diyAudio
